Today Only Deals!
Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/120G) @ £68.99 inc VAT
Kingston's SSDNow V300 solid-state drive is a cost-efficient performance upgrade that revives your personal computer and makes it more responsive. It's 10 times faster than a 7200RPM hard drive plus more reliable, more durable and shock-proof, with no moving mechanical parts. It features an LSI® SandForce® controller customised for Kingston and best-in-class components that are affordable for first-time SSD owners. SSDNow V300 is available in kits with all the accessories needed for an effortless transition to the latest technology for less than the cost of a new system. For added peace of mind, it's backed by a three-year warranty, free technical support and legendary Kingston® reliability.
Features:-
- Improves speed of loading applications and system boot up
- No moving parts, solid-state drives are less likely to fail than standard hard drives
- Design optimised to make migrating to an SSD more a ordable
- All-in-one kits with all the components for easy installation
- Multiple capacities to fit your workload
- 2.5-inch drive available in 7.0mm with adapter to fit in 9.5mm systems
- Cool and silent operation
Specification:-
- Form factor: 2.5" SATA
- Capacity: 120GB
- Controller: SandForce SF-2281
- Maximum Read: 450MB/sec
- Maximum Write: 450MB/sec
- Random 4k read/write: 85,000/55,000 IOPS
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- Warranty: 3 Years
Only £68.99 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Analog Gaming Headset @ £52.99 inc VAT
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels.
- Real 5.1 Surround sound with speakers aligned at a 12° angle
- Microphone with mute LED fully rotatable and completely removable
- Tip’N’Control desktop remote for central management of all volume functions
- Dual sound-profile with movie and game settings
- Solid aluminium hinges enabling heavy duty use
- Hand-sewn comfortable earcups featuring external noise cancelling
- Adjustable vibration unit for a realistic gaming experience
- Headband with three pads for equal weight distribution
- Easy to carry folding and compact design
Only £52.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- Capacity: 120GB
- Warranty: 3 Years
ORDER NOW
ORDER NOW
Maybe tomorrow
