** Thermalright HTPC and Low Profile Performance Coolers **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have some the new AXP-200 Cooler from Thermalright coming soon.
This is an exceptional step up from the AXP-100, I use the 100 in my home theater system with a super quiet fan and the performance on an i7 is brilliant.
The AXP-200 is low profile, larger than the AXP-100 and designed to hold a performance CPU at low temperatures easily.
Small Form Factor users, look no further.
The standard version is due this week.
We also have the ROG version due towards the end of August.
Thermalright AXP-200 Low Profile High Performance Cooler @ £48.95 inc VAT
Designed for low profile desktop systems.
Greatly enhanced airflow and surface for heat dissipitation.
Total height of 73mm(2.87 inches) including the TY-14013 fan.
Adjustable Fan Mount is capable of mounting 140mm fans and Thermalright 150mm fan.
Full nickel plating of the six heatpipes and heatsink body ensures optimal anti-oxidization.
Supports all modern CPU sockets and platforms.
Heatsink Specifications:
- Dimension: L150 mm x W140 mm x H60 mm
- Weight: 475g
- Heat pipes: 6mm heatpipe x 6 units
- Fin: T = 0.5 mm ; Gap = 2.0 mm
- Fin Pcs: 1+17+17+5+9 = 49 pcs
- Copper Base: C1100 Pure copper nickel plated
- Motherboard to Fin: 22+8 = 30 mm & 34+8=42mm
TY-14013 FAN Spec
- Dimension: L150 mm x H140 mm x W13 mm
- Weight: 90g
- Rated Speed: 700~1300RPM±15%
- Noise Level: 30.6dBA(Max.)
- Air Flow: 64.52CFM
Only £48.95 inc VAT.
ORDER NOW
Thermalright AXP-200R Low Profile High Performance Cooler ROG Edition @ £48.95 inc VAT
Specialist ROG Design to compliment high performance systems
- Weight: 475g
TY-14013 FAN Spec
- Weight: 90g
ORDER NOW
