Hello, I'm about to do my first overclock of an i7 3770k CPU, with an Asus P8Z77-V Pro board. I am using a Corsair H100 cooler. I have read everything I can find, and would appreciate someone checking my method before I start:
I am running Windows 7 64 bit, off of a Crucial M4 SSD. 16gb Corsair Vengence memory and a GTX 680 GPU. I would love to reach an 4.5 to 4.7ghz OC, but understand that my chip may not be up to it with a closed-loop cooler.
Any comments or tips would be much appreciated,
Thanks
- Download Intel Burn Test, Prime 95, Intel ID, Hardware Monitor and Real Temp.
- Boot into BIOS.
- Make sure all settings are correct:
a) Change AI Overclock tuner to M.M.P.
b) Turbo Ratio to Manual
c) EPU Power Saving mode to Disabled (can I leave this enabled for when leaving the computer idle?)
d) CPU Ratio to Auto
e) CPU Current Capability max out to 140%
f) CPU Power Thermal Control to 140
g) CPU Voltage to Manual Mode. - Increase CPU multiplier from 35 to 40 (first change).
- Boot into Windows. Run Intel Burn Test.
- If system is stable and temps are OK (below 80 degrees C), boot into BIOS and increase multiplier by 1.
- If temps are OK (below 80 degrees C), but system is not stable, boot into BIOS and increase CPU Voltage.
- Repeat steps 5 to 7 until max frequency is reached. Keep voltage below 1.3V (?) and temps below 80 degrees C (?)
- Run Prime 95 for 24 hours to do final stress test.
Thanks
