Answered your own question sort of - Its not steeped as long I would assume.
You guys keep mentioning steeping...what is it?
What did google tell you it was![]()
I still aint recieved my mesh and wire and all my stuff from the mesh company for over 2 weeks lol.
Google said something about soaking a liquid in the desired flavor for 'x' amount of time depending on taste or something...
So, do I just leave it be in the bottle with the lid on or so I need to do something to it? Want to leave my 'Story of Lip' to 'steep' if it makes it taste better as right now, it's pretty bland...
What would be the main benefit of using a variable voltage battery with a protank? Just seen the ego twist battery's on fasttech and its got me interested!
Just leave it sitting with the cap on, other than that not much else you can do.
So it's fine just staying on my desk, or should I put it else where? I won't be tempted to open it either as I wasn't keen at first...If that is all I do, will leave it till I pick up GTA V...should be long enough?
Since my first order with PinkMule and GLS failing to deliver for a few days I have put 2 more orders in. Both delivered next dayMy stuff only has to go from Madrid to Malaga mind. You guys get an epic journey for your GVC! Which probably aids steeping.
Going on a basic eGo for now until I can afford to buy a VW device...
Yeah you'll be fine then. They don't fire under 1.2Ohms anyway, so you just gotta try and get as close to that as you can. Like I said, 4 wraps of .3 ribbon kanthal (very different to .3 normal wire btw) does about 1.6-1.8Ohms for me and vapes quite nicely on an ego battery.
