- 17 Apr 2010
Hi,
Ideally I want this:- http://www.overclockers.co.uk/showproduct.php?prodid=CA-018-SS&groupid=701&catid=123&subcat=2383 but it's out of stock here and everywhere I look.
Which leads me to this which is in stock, and cheaper:- http://www.overclockers.co.uk/showproduct.php?prodid=CA-019-SS&groupid=701&catid=123&subcat=2383
Would the latter be enough to power:-
Stock 8350
VTX3D 7870 Tahiti LE again at stock speeds
3x HDD
1x SSD
H80
4 case fans (1 being on the H80)
Whilst it's my plan to under volt both the CPU/GPU, I should scope for the other end of the spectrum when both are over clocked just in case.
I don't plan to CF the 7870's (been there, done that) and if anything my future upgrade path would be to just get a single new card which will most likely benefit from a lower TDP anyway. I may be switching to Haswell in the next 3-6 months.
Thanks,
Chris.
Stock 8350
3x HDD
1x SSD
H80
Thanks,
Chris.
