Hi all, first post
I've looked through some threads already but apologies if I've missed an obvious answer to my questions. I built and upgraded 20-30 systems in the past but not for around 10 years, so I'm looking forward to this.
I'm planning a build to be used for gaming. I'm looking at a 7990 or GTX 780 (prob 7990) and a 4770K i7 (I could get by with an i5 but will put the i7 in there for possible future needs). So far so simple.
I don't like flashy lights or a massive ugly box, so ideally the place I'd like to house the case means it would need to have a max height of 450mm. Also I would love to hear as little fan noise as possible so I've looked at water cooling and noise damped cases. The top of the case isn't covered at 450mm (there'll still be airflow), it's just that the edge of my TV is that height.
What I was hoping someone could help with is: In your opinion can the heat issues of that CPU / GPU be solved acceptably in a smallish case? 450mm isn't tiny but I'm so long out of this game I would love to have opinions. Will this size force me into microATX, and if so is that a problem?
Thanks a million for any help! I don't want to compromise on machine power so if you reckon it's not possible that is useful info.
For info, here's what I've been looking at:
CPU: Intel 4770K i7
Cooler: Corsair H100 or H80 depending on case
MB: Gigabyte UD5H or 4H if ATX, unsure if not.
RAM: 16Gb of (haven't decided - recommendations?)
CASE: ??
PSU: ?? (still reading up, happy for any hints)
FANS: Some big ones! depending on case. Need for a separate controller?
OPTICAL: generic cheapo. Never use them, current machine has none.
BOOT HD: a decent 240Gb SSD
STUFF HD: 3TB decent HD, possibly 2 in RAID-1 depending on budget.
OTHER: I'll sort peripherals after everything else is decided.
CPU: Intel 4770K i7
CASE: ??
Georgie
