Computer Starts then Stops in an endless cycle
did you try with gpu tho? just incase it has something to do with it not starting up without a gpu installed
a cheap Pentium g620 would be your best option to test with,
Yes, tried with a GPU (nvidia GTX 460), but same thing: shuts down less than a second after it is powered on with a memory module installed.
I believe I have tested all possible scenarios and I'm quite positive it is either the CPU or the Mobo, but the only way to find out which one is with a different CPU, which I don't have.
I don't see anything unusual.
No, you`re right. Just checked it against another pic. It was just that it stood out from the rest, must have just been the way the light caught it.
So, it wont work with any ram module in any slot. Seems it`s a mobo problem. All you can do as wazza said and see if it`s ok when it`s had time to dry off.
Is your cooler still under warranty?
I've tried the original ram + another ram module that I have = no difference.
I'll try again tomorrow, but I don't have high hopes.
Warranty has expired :(
What makes you think it's the Mobo?
Could it be the memory controller inside the CPU - when a memory module is inserted then it shuts down for some reason.
I wish a could deduct one of both as the possible culprit without buying anything just for the test.
Shame the warranty has expired.
I`m not a 100% certain, but more inclined towards the mobo being at fault, especially with water added to the equation.
The only way to find out exactly which is at fault, is one of two means:
1. Try the Cpu in another mobo.
2. Or mobo with another Cpu.
Do you have any family members or friends who could assist with this, might save you spending money unnecessarily.
What neck of the woods are you in?
No friends of family with socket 1155 processors :(
I'm located in NW2 London. Maybe try a local computer shop, but they will probably charge me just for the test :confused:
Ideally you want to find a small one man outfit, it`s only a ten minute job, so if he does charge, it wont be much.
It turns out the computer is still under warranty after all. It was purchased Feb 17, 2011.
8. Warranty Claims.
8.1 The purchased product is covered under warranty by the "seller" for 3 years commencing on the date the "buyer" received the PC. This warranty is limited to 2 years parts, and 3 years repair/labour.
8.2 All hardware parts which are in a built system from the "seller" are covered for 2 years commencing the date the "buyer" received the PC.
8.3 Notebook computers purchased from the "seller" are covered for 1 year, commencing the date the "buyer" received the Notebook.
8.4 All monitors purchased from the "seller" will be warranted for 1 year only commencing the date the "buyer" received it. The "buyer" can often deal directly with the monitor manufacturers to obtain warranty claims for repairs/replacements. If the "buyer" chooses to use the "seller" for warranty repairs/replacements on monitors, the "seller" will deal direct with the manufacturer and obtain repairs/replacements from them.
8.5 Peripheral devices such as: Keyboards, Mice, Speakers, Cables, Surge protectors, Webcams, Headsets/Headphones, Routers/Modems, 3d vision goggles and accessories, USB sticks, Bluetooth dongles and External hard drives are covered for 1 year from the date the "buyer" received them.
8.6 All repair labour costs are covered by the "seller" for 3 years commencing on the date the "buyer" received the PC.
So does that mean they will only establish which is the faulty component and then I have to buy a new one?
If the leaked water cooler is the cause of the problem, isn't the company responsible for the fault?
The only way you will know is to get in touch with the seller. The problem is more than likely a result from the leaking water cooler. But if it is just a fault with the mobo, then you will most likely have to deal with Asus. But have a chat with the seller first and then see where your options lay.
