EVGA 770 4GB CLASSIFIED TEMPS
7 Jan 2010
Up NORTH
hi all
Are these temps normal for playing say planetside2
Depends how small your case is or fans and ventilation? What case are you using?
My one reaches that temp when running Unigine Heaven but in games (BF3) it goes upto about 68-72, 72 when its a hot stuffy day.
Wow that's a nice case you have there :) as retrogamer said will be fine but do make sure your fans are sucking or blowing the right way you never know :)
Hi,
EVGA do also allow to open the card, if you want to you can change the TIM on the card to high end one, this can help to get temps down. I would also recommend to set up a custom fan profile and raise the fanspeed earlier then the auto fan would do, this do also help to keep the card cool.
Generally thoe temps are ok.
