- 27 Sep 2012
- Telford, United Kingdom
Hi All,
I just wanted your opinion as to whether I should let my PC "Warm Up" after I turned it on first thing in the morning then log on after the HDD light doesn't flash or flashes at a slow rate after all the data has been read from the HDD.
Is it worth the time to let my PC "Warm Up" and do any of my fellow forum members do this?
If so why?
I do have fast boot turned off as my computer boots up quick enough without it enabled.
Also I would like to leave my PC on 24/7 and I know it will increase the leccy bill each month which isn't an issue, but is there any really any benefit from leaving PC on all the time for a matter of convenience other than a weekly shutdown and restarts for Software / OS Patches.
Will leaving my PC on 24/7 do any harm to my components and would you recommend it?
P.S I know this thread has the contents of two seperate threads but I wanted to do as they say "Kill two birds with one stone".
Cheers Shane
If so why?
Cheers Shane
a part of the forum you have never been in im guessing
