Gigabyte X3 670 SLI
e.g.
http://tpucdn.com/reviews/Gigabyte/GeForce_GTX_670_Windforce/images/power_maximum.gif
Quotes 242W for a single 670 alone overclocked.
670s running at 1300MHz+ will use a lot more power on top.
That's not real world usage. Techpowerups maximum = Furmark
Look at the same review but the Peak/Average readings. 170/153w respectively when overclocked. In normal usage a gtx 670 uses 150w stock and 175w overclocked (AC, actual power usage is lower but depends on the power supplies efficiency)
My single card at +130 core +700 memory, (1320mhz/7506mhz) cpus were an i5 3570k and an i7 3770k both at 4.5ghz, power draw for that was 340w total system draw. I use a 4 plug monitoring unit that has the case and monitor connected to it. If i get a chance later, ill fire up a test such as 3dm11 with my known stable gpu oc of +80/+600 for the pair and measure usage. Currently trying to get the cpu running stable.
That's no argument - if it can draw that amount in a benchmark taken over a year ago, who's to say it won't do the same in games over the next year or two? Normal use is just that - it's no good for determining what power it may require. If you can run a benchmark on your system and have it fail due to lack of power, you need a better PSU, simple as that.
No game will ever stress a card like furmark or else too many peoples cards will die a painful death. It's just not realistic at all.
If you do get that power meter, let us know what your power draw is for some games (Crysis 3, BF3 etc).
I think I'm going to buy one too... Someone donate a Titan to me? No GPU is horrid. :(
Ok, ive just ran 3dm11, gpu's clocked at +80 core, +600 memory. Cpu was at 4.5ghz on 1.2625 vcore. Highest i seen on the power monitor lcd was 586w for a second or so when running the first gpu test. This figure also includes my 24" lcd monitor as well, psu is a corsair hx 850w unit.
Which hx850 do you have? There's a couple of them with different 80plus ratings.
Mine is the older model, i bought it secondhand on members market about 4 years ago.
Probably the 80plus standard then?
If so actual power consumption could be as low as 468w (586x80%) minus a possible 95w for the monitor = 373w total for an overclocked 4770k with 670 sli. Just a guesstimate though :D
Id guess this psu has lost a bit of it's efficiency over the years too, it's had a pretty hard time in the 4 systems ive had it in.
That pretty much matches mine. on 3DM11, 670's @ 1254 Mhz, not sure what the memory OC was, 2600K @ 4.5. Highest from the wall was 510 W, given that my 850 W PSU is slightly more efficient than the HX and no 25" monitor with I would guess 40-60 W, more if it's old. Also my Blackgold BGT3650 Quad DVB-T2 was on too.
