** NEW CORSAIR VENGEANCE HEADSETS **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
You all knew they were coming
You all knew we would be first to list them
Corsair Vengeance 1400 Gaming Headset (CA-9011123-EU) @ £64.99 inc VAT
The Corsair Vengeance 1400 delivers high performance gaming audio that’s a perfect match for your high-end sound card. Large 50mm drivers offer better bass response and crisp, clear midrange sound and the noise cancelling microphone lets you be heard loud and clear. The closed-back, circumaural earcups reduce environmental noise for a more immersive gaming experience. Plus the large earcups feature microfiber-covered memory foam earpads for hours of comfortable gameplay. And the Corsair Vengeance 1400 uses standard 3.5mm connectors, for compatibility with virtually all PCs and Macs.
Features:-
- Large 50mm drivers ¡V Better bass response and crisp, clear midrange for more audio quality and a competitive edge.
- Designed for comfort ¡V Microfiber-covered memory foam earpads and a padded headband let you play longer
- Noise cancelling microphone ¡V Be heard loud and clear, whether you¡¦re playing or just chatting between matches.
- Large diameter, circumaural earcups - Blocks distracting sounds and keeps your head in the game.
- Compact, inline remote ¡V Easy access to headphone volume controls and microphone mute.
- Standard Dual 3.5mm Connectors - Compatible with virtually all PCs and Macs.
Specfication:-
Headphones
- Frequency Response: 20Hz - 20 kHz
- Impedance: 32 Ohms @ 1 kHz
- Drivers: 50mm
- Connector: Dual 3.5mm Jacks
Microphone
- Type: Unidirectional noise cancelling
- Impedance: 2.2k Ohms
- Frequency Response: 100Hz ¡V 10kHz
- Sensitivity: -41 dB (¡Ó 3 dB)
- Cable Length: 9.8 ft / 3m
Only £64.99 inc VAT.
ORDER NOW
Corsair Vengeance 1500V2 Dolby 7.1 Gaming Headset (CA-9011124-EU) @ £79.99 inc VAT
The Corsair Vengeance 1500 headset delivers high performance gaming audio over USB. Accurate Dolby 7.1 multichannel audio helps you pinpoint your enemies’ location before they see you. Large 50mm drivers offer better bass response and crisp, clear midrange sound and the noise cancelling microphone lets you be heard loud and clear. The closed-back, circumaural earcups reduce environmental noise for a more immersive gaming experience. Plus the large earcups feature microfiber-covered memory foam earpads for hours of comfortable gameplay.
Features:-
- Dolby 7.1 surround - Accurate multi-channel audio helps you locate opponents even if you can¡¦t see them.
- Large 50mm drivers - Better bass response and crisp, clear midrange for more audio quality and a competitive edge.
- Designed for comfort - Microfiber-covered memory foam earpads and a padded headband let you play longer
- Noise cancelling microphone - Be heard loud and clear, whether you¡¦re playing or just chatting between matches.
- Compact, inline remote - Easy access to headphone volume controls and microphone mute.
Specification
Headphones
- Drivers: 50mm
- Connector: USB
Microphone
- Sensitivity: -44 dB (¡Ó 2 dB)
Only £79.99 inc VAT.
ORDER NOW
Corsair Vengeance 2100 Wireless Dolby 7.1 Gaming Headset (CA-9011125-EU) @ £119.99 inc VAT
The Corsair Vengeance 2100 delivers high performance gaming audio without the wires. The powerful 2.4GHz connection gives you up to 40 feet of wireless range and up to 10 hours of battery life. Accurate Dolby 7.1 multichannel audio helps you pinpoint your enemies’ location before they see you. Large 50mm drivers offer better bass response and crisp, clear midrange sound and the noise cancelling microphone lets you be heard loud and clear. The closed-back, circumaural earcups reduce environmental noise for a more immersive gaming experience. Plus the earcups feature microfiber-covered memory foam earpads for hours of comfortable gameplay.
Features:-
- 2.4GHz wireless audio - High performance gaming audio without worrying about wires.
Specification:-
Headphones
- Impedance: 32k Ohms @ 1 kHz
- Drivers: 50mm
Microphone
- Sensitivity: -37 dB (¡Ó 3 dB)
Wireless
- Range: Up to 40 feet (12m)
- Battery life: Up to 10 hours
Only £119.99 inc VAT.
ORDER NOW
Would love to get my hands on an analogue corsair headset, shame, since i just recently upgraded my headset, so i will have to wait and admire these.
My headset has been making a funny noise (I mistreat it so bad) in the right ear... But can't justify the cost of one of these.
