Microsoft already shed some light regarding the APU that will be a key part of the upcoming Xbox One console and that actually has a die size of 363mm2 which is pretty large considering the fact that it is based on eight Jaguar cores and recent rumors suggest that it might even feature a discrete GPU that would be stacked inside the APU.
Anyway, as far as I know, there is no proof that Volcanic Islands is on 20nm. Places like SemiAccurate were saying they are still on 28nm for VI.
If this is true (and it won't be) the rumours suggest it will be significantly more powerful than the PS4, not level with it.At worst if this is true and the Xbox one is about 50% more powerful than it is now MAX it'll still be even with the ps4.
If true, then what you have is a S.O.C with a supposed TDP of around 100W (MS has mentioned this a few times), that has around 20% more shaders than a 7970 which requires 250W. MS have stated the S.O.C has 5 billion transistors a 7970 has 4.3 billion transistors, 0.8 Billion transistors are used for the Esram, and whatever the CPU/Audio chip etc need. hmmm
You'll have to ask the PS4 fans about that, some of them claim the PS4 is massively more powerful than the Xbox One.But what would the point be of a console thats MASSIVELY more powerful than its competition? All games will cater for the lower performance console mainly with only bells and whistles added for the xbox ones new found rumoured power. Ofcourse first party games will benifit but TBH i think Gears, Halo and Fable have had their day.
Makes no sense at all apart from appealing to the tech nerds like us which are a tiny portion of the market.
Why do people buy pcs
You'll have to ask the PS4 fans about that, some of them claim the PS4 is massively more powerful than the Xbox One.![]()
Thats because it is!! - double the shaders, DDR5 v's DDR3. Higher clock speed on the CPU too.
Use some common sense and take off the xbox blinkers bud!
Ha, spot the Playstation fan.
