Recommend router upto £60
18 Oct 2007
My WRT610T has decided it doesn't want to work, no internet access from it anymore. :confused:
So need a replacement, looking for something flat, good range and and easy to setup with virgin media.
Currently using the Virgin Superhub which has horrible range in hub mode.
If it's anything like my N56U, you will be able to detach the stand, but it's not meant to lie flat, there are no rubber feet or anything to stop it skidding around (which it will with the tension of cat cable sticking out of it). You'd have to secure it yourself or find another location to stand it up.
Asus to make damn good routers though.
