AMD & NVIDIA Cards in 1 PC -- Do-able ??
22 Oct 2006
I've currently got a watercooled EVGA TITAN SC in my PC. I'm doing a project to crack a password protected RAR file. From the research I've done it seems like ATI STream Technology can give a higher throughput on this type of work than CUDA based cards.
Here is the link that summarises performance
http://golubev.com/gpuest.htm
The question is - can i have the Titan as my main card and somehow have an AMD card running as a secondary card just to run the RAR password software.
You used to be able to run games on the AMD card and use a cheap nvidia card to get PhysX in them - when did they stop this? (Obviously there's nothing technically preventing this, which is why proprietary features in games are a bad thing!)
Nvidia have never allowed this, their drivers always disabled PhysX if they recognise an AMD card in the system. They released one driver that allowed it, but confirmed this was a mistake and the block was back in the next driver. Some people have found a way to modify the drivers to allow Hybrid PhysX but it's never supported and can cause strange issues on some games.
Yes, but I imagine the AMD card needs to work off it's own monitor in order to utilise AMD rendering/stream, is it cost effective though as I imagine it would have to be a half decent AMD gpu to outperform your Titan but I don't know which gpu you would need, just the fact it would work.
The comments above, in regards to a blanket statement of Nvidia disabling PhysX if an AMD card is present-PhysX is only disabled when rendering graphics through an AMD gpu.
If you render a PhysX game through an Nvidia gpu it works as advertised regardless if AMD is present in the system or not. :)
Hybrid PhysX can't be done anymore teppic since PhysX 3.0 released as it defaults to using cpu cycles instead-unless it has since been done.
Yes, but I imagine the AMD card needs to work off it's own monitor in order to utilise AMD rendering/stream, :)
Hmmmm.... that's an interesting thought. It's getting into the realms of far too much agg if I've got to run the AMD card into a monitor for it to come to life re stream capabilites.
Thanks Tommy - always happy to be corrected by someone who actually knows what they're talking about. :) Cheers.
I assumed this was the case otherwise your screwed if you have an AMD APU.
Just out of interest does it do the same if you use Intel built in GPU?
I ended up getting a watercooled 5870 from a well know auction site.
at £80 it's worth a punt. The 5870 seemed to give best bang for the buck.
If it bombs I can always sell it.
Thanks to all for the info.
Cracking hashes or brute force?
Come back and let us know, some figures would be great if you find the 5870 better than the Titan!
Protection RAR 3.X, SHA1, 128-bit AES
I'm expecting it to be a little bit slower than the Titan at SHA1 but it's 1/10th of the price. I'm going to see if I can get both working on the file at the same time. My licence for the recovery tool allows up to two GPUs at a time along with the CPU.
Just for a laugh I thought I'd dig the old 8800GTS out from the attic and throw it in the rig untill the 5870 arrives.
Amazing how the technology has come on in the last few years
90nm to 28nm
20 X RAM
10 X Memory Bandwidth
28 X Shaders
Spot which one is water cooled ??
It works!!!!
Pretty much doubled the speed of the recovery process for a measly £80
7000/sec to 14,000/sec
Yes you can have an nvidia gpu and amd gpu in same pc, you might need a dummy plug for the second gpu that isnt being hooked up via cable though
If you need assistance with cracking passwords or encryption, I may be able to assist.
For info, certain departments have server farms full of GPUs just for number crunching through bruteforce, backward engineering or dictionary attacks on passwords.
But have you cracked it yet? 6 billion isn't very many.
If you said a password could contain 94 characters (from a quick count on my keyboard!) then just allowing 6 character passwords gives you 689,869,781,056 combinations. If you let them be 12 characters you'd have over 475,920,314,814,253,400,000,000 combinations.
You're stuffed if it's not based on dictionary words. Hopefully it was compressed by a human who didn't use a strong/long password.
