- 17 Jun 2010
- London
Yes, those cyclist sprinters certainly don't lift for power.
er I always said I don't lift for power and size... I couldn't care about getting as big as possible.
My aim is to have a cyclist sprinters body which I will no doubt find easier to achieve.
but on the subject of cardio just finished my bike ride
1900 calories melted btw according to garmin which is apparently accurate to within 10% when using a heart rate strap
now to cook me some food![]()
they need big legs but the upper body looks similar to a regular sprinter like bolt and not exactly huge.
tbh I can already feel my thighs getting bigger and this is with running a massive calorie deficit :O
eating only 1500 calories a day and doing 20mile bike rides every 2-3 days which according to my garmin burns around 1900 calories.
need to drop about 2 stone :| then properly start working out hard
I can't lose weight from lifting like other people seem able toI just feel even hungrier than normal and overeat
at least not at a speed fast enough for me
Unless those 20 miles are twice up the Alpe d'Huez on a 40kg bike, you do not burn 1900 calories!
Their calculation uses user inputted variables including gender, height, weight and fitness class. It then combines this data with heart rate information from the ANT+ heart rate strap. Specifically, it evaluates the time between heart beats (beat to beat) to determine estimated MET (Metabolic Equivalent), which in turn is used determine actual work expenditure.
This makes the system one of the more accurate non-invasive options (read: doesn’t require a laboratory), within about 10% accuracy.
There is a white paper explaining how it works here
http://www.firstbeat.fi/userData/firstbeat/download/white_paper_energy_expenditure_estimation.pdf
it learns the user over time
anyway it's proven to be accurate to within 10% how can you say it's nonsense ?
nonsense would be if it didn't know
my age 32
height 6.35
weight 90
bike weight 15
activity level 6hours/week (I think I cba to check what it's set to)
if I am an athlete NO
what my heart rate was.
anyway it wasn't 1900 I just picked that number from thin air because I couldn't be bothered to check the exact number.
It was Calories: 1,538 which is only 769 calories an hour @ 81% max heart rate average
I only burn 2500 doing a marathon according to my forerunner, your garmin is way off, 1900 for a 20 mile bike ride lol, I could burn less than that running 20miles which uses loads more calories than cycling
Fitness is a crud term used by cardio bunnies, which encompasses a vast range of physiological adaptations from musculature, cardiovascular, central nervous system and pain thresholds...![]()
+1
Fitness is often miscontrued as endurance.
Fitness, as I have been lead to believe, is the body's ability to recover from/return to its normal resting rate/state after exercise.
Doesn't matter if Person A runs 10 miles in an hour and takes 5 minutes to fully recover, if Person B runs only 5 miles in an hour but takes just 3 minutes to fully recover technically they are the fitter. Perhaps not the best comparison but you should hopefully see the point.
The OP's crosstrainer might be a bit more difficult, but keeping 'form' whilst doing hard efforts running/cycling/rowing/etc isnt really hard?form goes out the window when you're at your max
Much more likely to pull something sprinting (I wouldn't class running as HIIT) than you are doing a comfortable paced run.
