Spec me an upgrade
14 Oct 2012
Hi,
I'm looking to upgrade slightly into the future (once I get my pennies saved)
I'm wanting to go into PC more instead of getting a next gen console, so i would like something that will be future proof for a few years.
Not quite sure on a budget just yet, but lets just say £500 for now.
I will be doing lots of rendering, gaming etc
Current spec, would like to try and keep as much of it as I possibly can (I expect a mobo and processor upgrade will be needed, maybe a new psu and some more RAM)
My current specs are
YOUR BASKET
1 x AMD A10-5800K Black Edition 3.80GHz (Socket FM2) APU Trinity Quad Core Processor **FREE SIMCITY PC GAME** (AD580KWOHJBOX) £99.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £74.99
1 x Gigabyte F2A85X-D3H AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard £68.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £49.99
1 x BitFenix Shinobi "Core" USB3.0 Gaming Case - Black £46.99
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £39.95
1 x Cooler Master 12cm Sickleflow Red LED System Case Fan - (CM-R4-L2R-20AR-R1) £6.98
1 x VTX3D HD 7870 Black Boost Edition 2048MB GDDR5 PCI-Express Graphics Card £155.99
1 x Silverstone Argon SST-AR01 CPU Cooler - 120mm (Socket 775 / 1155 / 1156 / 1150 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £28.99
If you want future proofing, it isn't with an FM2 set up.
AM3+ may not be future proof, but at your budget an FX6300 with AM3+ is probably your best bet.
I dont think martini realised that was your current rig (niether did i to start with)
UpgradE:
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £197.99
1 x MSI Z87-G45 Gaming Series Intel Z87 (Socket 1150) DDR3 ATX Motherboard £124.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £84.95
1 x XFX Pro 750W Core Edition '80 Plus Bronze' Power Supply £79.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £56.99
Total : £556.31 (includes shipping : £9.50).
Drop the SSD if you wish. :)
Thanks. I've edited my previous post to to try and make my current specs stand out a bit more.
Say I want to splash a little more cash and go the i7 route. What would you all recommend then?
Indeed lol.
Just get Doom's spec and throw the i7 4770K in it if you want.
Ah, that's great.
so is my current graphics card good? It plays everything out at the moment at max settings. So should be good for a few years if I start going to medium when I need to?
Ah, that's great.
the idea with my spec is its Xfire ready, so in a years time if it starts to struggle get a second 7870 and Xfire away. :)
