Desks for Triple Screening
19 Aug 2013
First of all I'm sorry if this is in the wrong area of the Forums.
So I am struggling to find a desk big enough for Triple Screen, My current desk is a L-Shape that can just about manage to fit 3 24" monitors on but I may push it to triple 27" monitors. If you know a good desks please let me know and feel free to post your desks always a fan of seeing other peoples gaming rigs.
Thank you
James.
Did you try 3x 27 monitos?
because I have 3x22.. and is ok.. I already tried 3x24 and is the perfect size...
I think 3x27 wouldn't be that nice, only if you seat far away from them.
i got this desk
Table top: 120x60cm
Could easily hold 3x24's maybe not 27's
If you have room either side, you only really need to worry about the bases of the monitors. I doubt many decent sized desks will have problems with 3 x 27" monitors (the outside two are best at a slight angle too), unless you have walls/furniture getting in the way.
I have an Ikea Fredrik without the top shelf/draw options and it's absolutely fine for 3 x 24" and no doubt 3 x 27". Also, a triple arm as suggested above, would be great as long as it has full tilt adjustment. Shame they seem so pricey for what they are
You can get metal arms which bolt/clamp onto the top of the desk and screw into the back of the monitor. These are the answer.
