GTX 660 - Sporadic Boost Clock? :(
Caporegime
8 Sep 2006
On Ocuk
In DayZ it's this, which is much lower than what it should be!
The Proper volts and Core clock below
Looks ok to me
Hmm Guess not
Day-z is known as a poorly optimised game and wouldn't think it would be the card.
Does the same happen in other games?
Hard Rest sometimes it's at full wack, other times it's that lower frequency/speed.
Will try a few more games
What drivers do you have installed too! I had issues with some older/other graphics drivers not being removed.
http://forums.guru3d.com/showthread.php?t=380942
Works amazingly in Battlefield 3 by the way! Maybe it's due to DayZ being cpu intensive so the GPU isn't used as much, thus it doesn't boost fully. In Hard Rest the reason it goes up is because the action is really kicking off but when no baddies are attacking, it drops off again even though it's at 60fps
Sound about right?
