For that money I would go Giga UD3 or even better UD5.
Its the UD3 that I keep looking at, but they seem to be rev 3 and as said I would like rev 4. Would there be much difference between that and the sabertooth? Both for overclocking and general performance?
OK thankyou both for your great advice![]()
Is an arctic cooler 13 good enough?
No problem.
With the UD3 if you use BIOS FDc and disable APM then its solid.
Of course do in sure you have good cooling for the CPU too.
Here is a UD3 with a FX8350 running Prime solid for a bit,
Teppic is wrong and the fact it doesnt support a much more power hungry CPU has no baring on a FX8350
It does when you're talking about overclocking an 8350, which is precisely the question. The UD3 rev.3 doesn't support Piledriver even at 4.4GHz according to Gigabyte.
No.
It doesnt support the FX9370 and 9590, both 220W TDP chips.
The 8350 is a 125w TDP chip and is supported and runs fine and I have used/tested it myself.
The Rev4.0 brings support for 220W FX chips and a new USB controller.
