Apple hard drive upgrade
16 Apr 2013
Finchley Central
I want to upgrade my apple hard drive on my macbook mid 2010 to a solid state drive. It isn’t a macbook pro.
1) Can you please suggest an SSD?
2) Will I be able to reformat the hard drive inside the macbook and use it for my pc? Is this straight forward to do?
Crucial, Samsung Either brand would be good. Get the biggest size that you can afford and be done with it, I think yours is a SATA 2 only machine so no point spending money on a Pro drive. The SATA 2 interface will be your bottleneck.
I have a Crucial M4 512G in mine.
And yes, you can format the old HDD, I put mine in a caddy and use it as a portable drive.
Any SSD.
Samsung 830, 840, 840 Pro or 840 EVO are all highly rated.
But the biggest you can afford and ignore specs, because you simply will not be able to tell the difference!
I don't know about the MacBook, but it's possible to swap the DVD drive out on the Pro models and have both your original HDD and the SDD in the machine. All you need is a cheap conversion kit off eBay, a torx screwdriver and a little patience.
Raymond do you have any guidance on how to format the hard drive?
Did you use carbon copy to move the data from one hard drive to the other?
Tunney does this mean that on the pro you forfeit the ability to put in cd's? I guess this is a reliance on online downloading, networking and usb.
Yeah. Most of the MacBook range and the new iMacs don't come with a DVD drive. Even boxed Mac software is usually either a USB key or simply a download code these days. The only time I need a DVD drive is when I'm ripping CDs and DVDs. I have a £20 external DVD drive for when the need arises.
I recently fitted a Samsung 840 Evo 256GB drive into my 2011 Mac Mini i7, 16GB RAM, Radeon blah blah
Absolutely lightening fast. Load times don't appear any slower than my 2013 MBA i7 256GB SSD 8GB RAM etc etc machine
The hard drive can definitely be a huge bottle neck.
Tunney - This macbook isn't a pro so I haven't found anyone upgrading online (only pro's). I am capable of making the upgrades, but my knowledge is low. What could you foresee as being an issue on a macbook compared to a pro on the removal and fitting of an SSD into the optical slot.
