Games you have are CPU limited DayZ recommends an I5 with a GTX260 ..... clearly needs a good CPU while the GPU is just a means to display the output.
You may benefit for a I7 due to HT, a good OC to 4.5Ghz would help.
I'd say check 3dmark for to ensure the system is working, other than that, OC CPU, fast ram and SSD.
Do the games play ok ... usually not that fast paced. Turn of the FPS counter in the corner and see how it goes. 30-40 fps is usually fine in anything but a twitch shooter ... measuring just brings unhappiness
AD
AD
