Hi all ,
Suspect my card has unexpectedly died , really disappointed but things happen. Just wanted a few confirms or ways to totally confirm its dead.
I basically fitted a h80 cooler bought from ocuk. Removed the graphics card correctly sliding out perfectly. Fitted the h80 ,,, eventually. Put my card back in slotted in fine. Connected up the hdmi, power pin and powered up.
No boot. Just h80 whirring loudly. That's odd. Checked the connections , 7850 powered and all well. Amended fan setup on the motherboard for h80 then attempted to boot again.
This time system span up fast the slowed down to manageable level. Seemed from the led's system was booting. But nothing on screen at all. 7850 was spinning perfectly , both fans and power connector fully pushed in. I was stumped.
I then tried booting from the motherboard connections. It booted. I went into the bios. Checked the graphics options as it was going to use the igpu I guess. It did show PCIE x16 lane - x0. Which began to worry me. I then grabbed the only other graphics card I had a 5570. To see if the mobo pcie slot was faulty. But it booted first time. So now the 7850 is looking bad.
That's where I'm up to. I've contacted the seller from the mm I bought it from to see if he can help me RMA. I will look to try the card in another system today to see if it works there.
Is there anything else I should test or do before I accept this is dead.
