May be you should go have a look over at the graphic forum and see how people are calling the recommended 3GB graphic memory for BF4 being BS, because AMD are in bed with the developerAnd game developers recommend an 8350 over an i5 for future proofing with next gen games. Strange attitude for something so inferior.
As has been said throughout this thread by people who actually use the CPUs, the 8320/50 is a good choice for gaming, particularly considering the price. Both 8320/50 and 3570K make good choices for current games, but on a strict budget the higher price Intel CPUs would mean sacrificing other things.
"Most games" ain't half as nearly heavy threaded as BF3...Most games are not limited by the CPU. As easily seen from this graph, there's no scaling issue with the 8350 compared to the 3770 at any common resolution with this multithreaded game:
..for those that don't or can't, the FX8320/FX6300 are good choice around the £100 budget, and not once did he recommend getting a Intel i3.
Unless I'm silly, the OP hasn't stated a budget.
Saying "I'm on a budget" means nothing, as a budget is the amount you're spending, and the difference between the two chips in the OP is 30 quid.
I wasn't referring to you specifically, I was just saying people in general who gang up on Martini calling him Intel fanboy so conveniently ignore or overlook the fact he recommends the FX6300/FX8320 over the Intel i3 all the time.I never mentioned i3.. who are you talking about?
Far too many people bashing for bashing's sake.
What would you like to know?
lol I totally miss that 27p per month
TBF if I had to buy a new motherboard and CPU now, I might have made a different choice, AM3+ is looking more and more like a dead end socket. The price of an 8320 and having a 990FX board, it was a no-brainer
Toms (like most places it seems) results with this chips don't really line up with my user experience. It was the same with my A10 laptop - consistantly getting better minimum/averages than reviews.
I've been called an AMD fanboy before but that's not really the case, I've had/still have every platform bar Haswell and the E hex cores. I'm a technology enthusiast and AMD make more quirky products at the moment.
I think if you have a crappy experience with a game that does not run well enough on an FX63xx and up, you'll only have a slightly less crappy experience on an Intel i5 and up system.
I think that's the issue with the AMD CPU at the moment- there's no consistance for their CPU performance for gaming, as different games would address and use different number of cores/threads.With PC's in general we can all wait another week and get the better tech/price. You cant always tick the boxes when purchasing with regard to:
Longevity
Price
Performance
Upgradeable
The biggest problem is more than 95% of the games on PC runs on 4 or fewer cores/threads, which would would make the 8 cores CPU far from delivering its full potential. We would have the FX8 running as FX8 in heavily threaded games such as BF, Crysis 3 etc no problem there, but for games that use 4 cores/threads or less, the FX8 would be running like a "FX4" (if you know what I mean). Yet we got people bushing it off as "it's not an issue at all" and always try their best NOT TO bring that up, how exactly is that gonna help people that are genuinely seeking advise before parting with their cash?
But thing is not a simply case of "more cores, any CPU would do". It's no secret now that Core2Quad would perform better than Core2Duo in games that use 4 cores/threads, but that's because their per core performance were quite similar; for the FX8 their per core performance is much lower than the Intel i5, so their best case scenerio would be equal to the i5's level (if comparing both CPUs at same clock speed), but slower in pretty much everything else that don't address and use all of its cores.Absolutely.
Take my processor though the C2D, back then I felt that quad was not required (as it was available) and the current or anticipated games did not need 4 cores back then.
Now you see many swearing by the quad cores..
It's just hedging the bets hoping if you get the one with more cores it could be beneficial in the not so distant future (this time round for me).
Yes. The consideration would then be what do you use the machine mostly for and if you would ever use software that would harness the additional cores.
Are other games going to follow BF4 and start using more cores, or are GPU's taking the meat moving forward?
Just to clarify I didn't mean ALL multi-threaded apps, I was talking strictly about gaming performance. For things such as encoding etc the FX8 would possibly be faster than the i5.basically he says that as the ipc of the intel is so much better. even in multi thread apps, the intel will likely be the same or even still better. NOT favour the amd.
everybody knows here i was a amd fanboy for so long. but after going from a 1090t 4ghz to a amd FX 8 core 4.5ghz, i was so disappointed has tbh the performance was a downgrade in everything even gaming, so i went to a I7 and tbh that performance blow amd out of the water in everything.
You had an FX8150,ie,a BD CPU. BD is not PD. An FX6300 beats an FX8150 even in multi-threaded games:
http://www.bf-blog.cz/wp-content/uploads/2013/06/bf4procesor.jpg
The FX8350 is far ahead of any i5 in encoding and rendering and similar tasks where load can evenly be distributed, that is no secret.
