- 1 Sep 2013
As everyone will know iv been trying to sort out my 4.2 and 4.3ghz overclocks on my 4670k ( other threads can be deleted by mods, and im sorry for being a problem) but IBT After 20 runs has top core temp as 81c on IBT high settings.
on prime 95 however after 20 mins small ffts im getting max core of 67c, hour in blend is 68c tops.
Idles after half hour at 41c tops averaging 30to 35.
This is on the 4.2ghz
I don't know the ambient room temp as i have nothing to check it with, its quite hot tho and outside temp is 18c.
The settings are as follows:
42 cpu ratio
40 ring ratio
Vccin: 1.860
Vcore: 1.200
Ring voltage: 1.125
Its on fixed mode running all cores, not dynamic.
I know iv been a pain in the backside but can someone please answer this and confirm my temps are now ok?
Many thanks and apologies
42 cpu ratio
40 ring ratio
Vccin: 1.860
Vcore: 1.200
Ring voltage: 1.125
