What colour is the radiator?
If you turn a radiator on, does the relative humidity in the room increase or decrease?
Shakes fist at above...
Absolute humidity is the measure of how much water vapour there is in the air.
Relative humidity is the ratio of current water vapour to max (saturation) for the current temperature.
Hot air can hold more water than cold air, so relative humidity will go down as the temperature increases (assuming the absolute humidity [amount of water vapour in the air] stays the same).
White.
I'm out.
Racist.
