Who do I have to throw my money at to get one of those?
They are not in retail channel as yet. Early October I believe. I helped launch the board benching live last night. Mine is running very well
So tempted to save up and go for a 4930k and this board!
YOUR BASKET
1 x Asus Rampage IV Extreme Black Edition Intel X79 (Socket 2011) DDR3 Motherboard £389.99
Total : £400.79 (includes shipping : £9.00).
hoping ocuk can do the overclocked bundle with that board so I can get a good chip
They are not in retail channel as yet. Early October I believe. I helped launch the board benching live last night. Mine is running very well![]()
Can I ask which cpu you were using and what sort of clocks? I'm really tempted to buy this board and use a 4930k
Is the main difference between a 4770K and 4820K access to socket 2011 which allows 16x/16x in sli?
Does socket 1150 or 2011 have a longer life ahead of it?
Ivy-E can perform extremely well with high memory speeds and normal cooling.Good progress though, showing that with a little tweaking and an 8 Pack in your pocketIvy-E can perform extremely well with high memory speeds and normal cooling.
When you say "normal cooling" what cooling are you using for the cpu?
With a little help from 8 Pack today I managed to sort out getting my ram to run at full speed while the CPU is at high clock speeds.
We started adjusting VCCSA and I found that more than anything else it needs help in this area when in the initial boot phase. There is a setting in the Asus bios that lets you set this specifically for the initial boot and setting this to 1.3v while normal VCCSA was set to 1.2v enabled my ram to run slightly above stock speed and with the sort of timings that it was capable of with Haswell.
Although with slack timings I could run the ram right up to 2800 - again much the same as with my best 4770K
A little more VCCSA lets me in at 5.0GHz CPU and 2666 ram, but I need a bit more tweaking to make that stable.
