Ye, the 10GBe is so I can map the drives with a few additional tricks and make windows on my main box think the raid I'll be plugging into this is a local drive
Got the network side of it about covered. The raid card can do around 400MB/sec in raid 5 with the right amount of drives, I'm rather used to the speed and wanted to move all my storage to one box in the house, backups etc are then easier too.
All eggs in one basket etc I know but raid 5 + backups means I can keep the data safe, the box will be built with some thought towards making sure power + cooling needs are covered and short of dodgy hardware I doubt I'll have much issue, not had any kit fail me in a significant amount of time. The raid controller is battery backed too so there's no issues on power cut etc even with higher performance options set.
Cost of hardware wise I'll need to buy something regardless and the shopping list looks pretty cheap as things sit.
Edit: checking the celeron processors at the moment (admittedly its G550) it lists it as a 65w part. Checked the listing for the G530 and it's listed as 65w too. We sure on the readings from the setup you had decto?
