Recommend some internet based on these requirements
19 Jun 2009
I’ve purchased a new house, currently no phone line or internet is connected.
Checking on Sam knows, cable is not available however fiber is available showing 51MB download on the BT checker.
These are my requirements.
1) Work from home, no limitations on VPN, so no ports blocked etc.
2) Static IP. Will be hosting some small bandwidth websites.
3) Unlimited access, however currently using 100GB a month, would expect to double this soon. This is without any P2P.
4) Network not overly contended, no major speed drops at school leaving times etc.
5) Ok to use your own router.
6) Good uptime, competent technical support a bonus.
In addition, will need a phone line so can take in same package.
Any recommendations that meet the above.
Cheers
Jason :)
Hi Gman, yes I was thinking of PlusNet but did not want to plant the idea, and hoped someone else would recommend :) Was thinking of Plusnet unlimited fiber and phone with the £5 static IP.
Is there anyone else worth considering?
How does the £5 static IP activation happen on PlusNet. Is there an option when your doing the initial order, or do you contact PlusNet about this afterwards.
Yeah, I just added the static IP after I got my account with them online. I have a phone line with them and pay the annual charge instead of monthly as it works out a lot cheaper.
Thanks for everyone's help, ordered plusnet unlimited fiber with phone line, BT have to connect a new line also, will be 2 weeks away.
