I've been asked to do a build...
IC3
IC3
3 Dec 2011
Wouldn't he need some form of graphics card or is the IGP enough? Could always look at Trinity/Richland?
The AMD x4 you've spec'd isn't an AGP unit.
I haven't woke up yet.... I was meant to put a A8 5600k in. :o
EDIT
E.g.
YOUR BASKET
1 x AMD A8-5600K Black Edition 3.60GHz (Socket FM2) APU Trinity Quad Core Processor (AD560KWOHJBOX) £71.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (TXD38G2133HC11DC01) £65.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £50.99
1 x ASRock FM2A55M-DGS AMD A55 Chipset (Socket FM2) DDR3 Micro ATX Motherboard £41.99
1 x OCZ CoreXtreme 500w '80 Plus' Power Supply £35.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £332.02 (includes shipping : £11.75).
It happens :)
I would recommend Richland due to the low power consumption and the quality of the AGP. Intel are getting there, but AMD's is better.
YOUR BASKET
1 x Gigabyte F2A85X-UP4 AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard £88.99
1 x AMD A6-6400K 3.90GHz (Socket FM2) APU Richland Dual Core Processor (AD640KOKHLBOX) £59.99
1 x Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply (CP-9020046-UK) £39.95
Total : £370.98 (includes shipping : £11.75).
If he prefers consoles why force a pc on him?
If you swap the althon out for an A8 that would be much better
Well, he want's his own PC for Minecraft and other things such as Youtube.
As I said he prefers consoles, but he keeps mentioning PC and because xmas is not that long ago, he asked for a PC.
ohh okay. Good times.
I like snips spec but maybe go for a cheaper A75 motherboard.
I used exactly same mobo for my previous amd budget build. I bought a 2666mhz ram but the mobo spec says:
Memory 4x DDR3 1866/1600/1333/1066 MHz memory modules
Big facepalm...:(
EDIT:
But it actually works on 2133mhz so...
EDIT:
Something like this?
YOUR BASKET
1 x ASRock FM2A75 Pro4-M AMD A75 Chipset (Socket FM2) DDR3 Micro ATX Motherboard £59.99
1 x Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler £19.99
Total : £370.01 (includes shipping : £11.75).
I wouldn't touch and ASRock motherboard with a barge pole mate, stick with something from the big 3 (ASUS,Gigabyte or Micro Star International).
