Can anyone spec me using this case?
Will that cards cooler not be a bit tight?
What's the OP going to be playing gaming wise? Do you need a full on high end GFX card? Or are you going to be playing footy manager games?
Can i ask the choice in terms of gfx card?
It's an exhaust card, so the hot air will be dumped out the back, not in the case.
Nope, it's a dua slot card that'll fit fine.
Will the H100 fit in there?
There is a space at the top of the case for 2x120mm fans with RAD mounts, the H100 will be fine. You could alternatively fit it on the front.
Quick question again sorry for this are the fans loud? the corsair pack
If i were u , and had a couple of spare change the gtx 770, that will last you a couple of years really , will be able to play the new games like bf4 etc but i mean you could go for a cheaper one if u wanted to save some money like the gtx 680
that is a very good gpu, if you can afford it with the other components its perfect
yeah what i'll do is i didnt really want a 250gb ssd, ill go for a 120gb for now i can always add another later if i want, so ill have the 120SSD a 1TB HDD and that GPU :)
Since that version of the case has a side window instead of a vent, you'd be pretty much restricted to blower-style graphics card coolers.
The ACX cooler is decent in a normal case, but since there's no vent on the Prodigy side panel it'd get starved for air.
ive been wondering about this.. what options should i go for?
