- 16 Jun 2011
EDIT: My new question is at the bottom of page. Im putting off getting a new card for now.
Clock that cpu of yours up and make the most out of either:
1 x Asus GeForce GTX 670 DirectCU II 4096MB GDDR5 PCI-Express Graphics Card **FREE SHIPPING** £229.99
As you mentioned two titles that make use of Advanced PhysX, then 670 is the card to give max IQ in that case.
The 2GB version is £14 less, personally, right or wrong I wouldn't take the chance on 2GB myself.
Should still get Batman: Arkham Origins which is another Advanced PhysX title and Splinter Cell Blacklist games.
Or if you want cheaper but minus the Advance PhysX:
1 x HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M) **Voltage Unlocked** £191.99
This should come with Bioshock Infinite, Farcry3 Blood Dragon and Crysis 3 and if you are lucky(some got them also last week), you might get the AMD Radeon GOLD Reward Ticket also(another 3 games you pick from a list).
If you don't like to OC, the 670 may be the better choice as it (mostly)does it for you, on the other hand, the 7950 has a hefty OC potential as it's lower clocked in comparison out the box.
If you don't want to OC your cpu, then keep what you have as the above cards may be wasted in your system.
You can try to overclock your pc back, have a look here:
http://forums.overclockers.co.uk/showthread.php?t=18383232
and
http://forums.overclockers.co.uk/showthread.php?t=18383228
from a 6950 to a 7950 you will get about double of the performance.
and
Im not really sure where you got "double the performance" from but nearly every benchmark ive read suggests merely a 10 to 30fps increase depending on the game and res
what motherboard do you have Malmortius ?
on my i5 750 i simply upped my cpu ratio to 19 or 20 then upped the base clock,try for around 3.5ghz first,may need to up the vcore but try not to go over 1.3,start at 1.2 , its possible it wont OC aswell with all 4 ram dimms filled so 3.5 should be a good starting point
http://apcmag.com/overclocking-101-our-step-by-step-guide-to-maximising-your-pcs-speed.htm?page=4
Have you got a source to back that up ? benchmarks that show a 7950 any edition being twice as fast as a 6950 please![]()
http://www.anandtech.com/bench/Product/510?vs=550
http://www.tomshardware.com/reviews/radeon-hd-7950-overclock-crossfire-benchmark,3123-6.html
like i said, old benchmarks..
I had a 6950 and I have a 7950, so I'm not talking about internet benchmarks.. I'm talking about my own experience with both cards, both Overclocked.
