Corsair 350d build - £1000
24 Dec 2010
Anglesey
Looking to buy a build for this case.
Not planning on overclocking.
Only the system is needed, no o/s.
Would like a colour theme.
Intel only.
Budget - £1000
Thanks guys, will be going on doomed's build, only change I will be doing is change the cables for the alchemy bundle one, and add 4 corsair sp 120 fans, and a fan controller. Staying away from the optical drive, it spoils the look I think.
How long should this build last me before I have to upgrade again? It should handle the upcoming games on high settings right?
The bundle only has 6 Pin PCI-E's IIRC, thats why i went seperate because you need 2 x 8 pins for the matrix..
That'll look ace. :D
Yeah will handle everything mate, the 7970 is an absolute beast the matrix is the best of the 7970's (bar the lightning maybe)..
This will last years and years mate. :D
