** ALL THE EPIC NVIDIA DEALS IN ONE THREAD!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
And here is all the great NVIDIA deals were currently running and on THIS WEEK ONLY:-
Gainward GeForce GTX Titan 6144MB GDDR5 PCI-Express Graphics Card @ £799.99 inc VAT
The worlds most powerful single GPU graphics card!
- GPU: GeForce GTX TITAN
- Core Base Clock: 837 MHz
- Core Boost Clock: 876 MHz
- Memory Clock: 6008 MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2688
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£839.99] Inc. VAT
Only £799.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 863 MHz
- Core Boost Clock: 902 MHz
- Memory Size: 3072MB GDDR5
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£529.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Asus GeForce GTX 780 Direct CU II OC 3072MB GDDR5 PCI-Express Graphics Card @ £539.99 inc VAT
The newly arrived ASUS GTX780-DC2OC-3GD5 ships with 28nm GPU and 3GB GDDR5. To fully harness the power of new GPU technology, ASUS GTX780-DC2OC-3GD5 built with ASUS exclusive DirectCU II design featuring a 40% more efficient 10mm copper heat-pipe, 2.2X larger dissipation surface are and unique CoolTech fan that ensures 30% cooler and up to 3X quieter performance than reference. For enhanced overclocked headroom and gaming experience, ASUS redesign GTX780 with DIGI+ VRM offering precise digital delivery for better software overclocking stability. For enhanced overclocked headroom, ASUS GTX780-DC2OC-3GD5 uses 8+2 phase power design in Super Alloy Power technology, compared to 6+2 phase power design in reference card. In addition, GPU Tweak utility helps users modify and tune boost clock speed, power target, temperature target and fan performance via an intuitive interface. This card uses PCI Express 3.0 as the standard interface, doubling the data bandwidth of PCI Express 2.0. The power of ASUS GTX780-DC2OC-3GD5 also supports NVIDIA® Adaptive VSync technology and 3D Vision® surround™. ASUS GTX780-DC2OC-3GD5 provides fantastic gaming experience!
Features:-
- 941MHz Boost Clock
- 30% cooler and 3X quieter performance with ASUS exclusive DirectCU II thermal solution
- ASUS uses 8+2 phase power design in DIGI+ VRM and Super Alloy Power technology for precise digital delivery and enhanced overclocked headroom.
- GPU Tweak utility allows you to tune graphics card performance and check card status via an intuitive interface
Specification:-
- Core Boost Clock: 941 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£559.99] Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 780 ACX Superclock 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2784-KR) @ £551.99 inc VAT
Features:-
Specification:-
- Core Base Clock: 967 MHz
- Core Boost Clock: 1020 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£569.99] Inc. VAT
Only £551.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 780 WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N780OC-3GD) @ £515.99 inc VAT
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
In the Kepler architecture, support up to four displays on a single card. Satisfy your mulit-screen steup, high definition and extreme gaming experience.
Features:-
Specification:-
- WINDFORCE 3X 450W Cooling system
- Black PCB
- Core Base Clock: 954 MHz
- Core Boost Clock: 1006 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£539.99] Inc. VAT
Only £515.99 inc VAT.
ORDER NOW
MSI Geforce GTX 780 Gaming Edition 3072MB GDDR5 PCI-Express Graphics Card @ £515.99 inc VAT
Features:-
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
MSI Geforce GTX 770 Gaming Edition 2048MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
The GeForce® GTX 770 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1059MHz (GK104)
- Core Boost Clock: 1111MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2118MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£329.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
OcUK Geforce GTX 770 2048MB GDDR5 PCI-Express Graphics Card @ £293.99 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
Specification:-
- Core Clock: 1046MHz (GK104)
- Core Boost Clock: 1085MHz
- Shader Clock: 2170MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£299.99] Inc. VAT
Only £293.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 760 2048MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
The OcUK GTX 760 is a powerful, feature-rich card stacked with advanced gaming technologies like NVIDIA® PhysX®, TXAA™, ShadowPlay, and much more. This gives you the performance edge you need to take on next-generation titles like Splinter Cell: Blacklist and many others. It's serious equipment for the serious gamer.
Specification:-
- Core Clock: 980MHz (GK104)
- Core Boost Clock: 1033MHz
- Memory Clock: 6008MHz (Effective)
- Processing Cores: 1152
- Shader Clock: 1960MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£185.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Asus GeForce GTX 670 DirectCU II 4096MB GDDR5 PCI-Express Graphics Card **FREE SHIPPING** @ £199.99 inc VAT
***FREE SHIPPING***
The new Asus GTX670-DC-4GD5 with Digi+ VRM for the ultimate power control and enhanced Overclocking comes with the Asus exclusive DirectCU II for up to 20% better cooling.
The GeForce GTX 670 graphics card taps into the powerful new GeForce architecture to redefine smooth, seamless, lifelike gaming. It's more than state-of-the-art technology and features. It's truly game-changing performance.
Faster:
- Innovative new GeForce architecture-designed to deliver faster, more power-efficient performance
- The power to turn on lightning-fast antialiasing in a huge variety of games, automatically, with NVIDIA FXAA
- Support for new temporal antialiasing (TXAA) technique that delivers the ultimate combination of image quality and performance.
Smoother:
Richer:
- NVIDIA® Surround™ multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display)
Features:-
- Double the reference video memory at 4GB takes your gaming to new levels of smooth.
- Flattened copper heatpipes makes direct contact with the GPU surface so heat is dissipated efficiently, delivering a 20% cooler and vastly quieter performance than reference.
- Acclaimed DIGI+ VRM with 8-phase Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking.
- GPU Tweak utility helps you modify and tune clocks (including new boost clock settings), power consumption targets, voltages, and fan performance via an intuitive interface
Specification:-
- 20% cooler and Vastly quieter performance with ASUS exclusive DirectCU II thermal solution
- ASUS DIGI+ VRM technology with 6+2 phase Super Alloy Power for precise digital delivery and enhanced overclocked headroom. (compared to 4+2 phase in reference card)
- Full length PCB, better for overclocking
- Core Clock: 915MHz (GK104)
- Core Boost Clock: 980MHz
- Memory: 4096MB GDDR5
- Processing Cores: 1344
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 2x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- With FREE Splintercell Blacklist PC Game
- Warranty: 3 Years
Was [£239.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 670 4096MB GDDR5 PCI-Express Graphics Card (ZT-60303-10P) with Batman & Splintercell PC Games @ £199.99 inc VAT
Transform your gaming experience with the ZOTAC GeForce® GTX 670 powered by the latest generation NVIDIA® GeForce® architecture that breathes new life into PC gaming with smoother frame rates and lifelike visuals. The ZOTAC GeForce GTX 670 with new NVIDIA GPU Boost technology dynamically maximizes clock speeds on the fly for that extra performance edge in gaming scenarios when there is energy headroom available.
New NVIDIA Adaptive Vertical Sync technology delivers maximum playability by dynamically adapting the display’s vertical-sync to a game’s frame rates for unmatched smoothness on the ZOTAC GeForce® GTX 670. When a single monitor isn’t enough, the ZOTAC GeForce® GTX 670 is NVIDIA® 3D Vision™ Surround ready for stereoscopic triple-display gaming that delivers unprecedented immersion.
Specification:-
- Core Clock: 928MHz (GK104)
- Core Boost Clock: 1006MHz
- Shader Clock: 1856MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was [£229.99] Inc. VAT
ORDER NOW
MSI GeForce GT640 4096MB GDDR3 PCI-Express Graphics Card @ £71.99 inc VAT
The MSI GT 640 4GB supports all of the latest features of New GeForce 600 series, including Adaptive Vsync for smoother game play, PhysX, DirectX 11, and Blu-Ray 3D support. The GT 640 is also the first mainstream GeForce graphics card capable of driving up to 3 displays for surround gaming and general use, making multi-display more accessible and affordable than ever. The most common display types are supported right out of the box, including HDMI, DVI, and VGA.
- 384 Cuda Cores
- 902MHz Core Clock
- 1804MHz Shader Clock
- 4096MB GDDR3 Memory
- 1782MHz Memory Speed
- 128-Bit Memory Interface
- Cool, Quiet, Fast and Affordable
- Better Videos, Photos, Web, and Games
- Greater Productivity
- SMX power efficiency
- Quad display support
- Connections: 1x DVI-D, 1x HDMI, 1x D-Sub
- TDP 65W
- 3yr Warranty
Was [£79.99] Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
MSI GeForce GT 610 SILENT Low Profile 1024MB GDDR3 PCI-Express Graphics Card @ £25.99 inc VAT
The powerful new GeForce GT 600-series architecture delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that will transform the way you experience all your favorite titles now and in the future.
Features:-
- Provide the best environment for gaming and multimedia.
- Low profile design perfectly works with slim or smaller system.
- 10 years ultra-long lifetime (under full load).
- Lower temperature and higher efficiency.
- Aluminum core without explosion.
- HDMI 1.4a supports 1080P HD movie playback and TrueHD or DTS-HD audio transmission.
Specification:-
- CUDA Cores: 48
- Core Clock (MHz): 550
- Boost Core Clock (MHz): n/a
- Processor Clock (MHz): 1100
- Memory Amount: 1GB DDR3
- Memory Interface: 64-bit
- Memory Clock (MHz): 1000MHz effective
- Memory Bandwidth(GB/sec): 8
- Texture Fill Rate (billion/sec): 13 / 6.5
- Direct X 11
- Outputs: Dual DVI-I / HDMI / VGA
- Power Connectors: None
- TDP: 29W
- 3yr Warranty
Was [£29.99] Inc. VAT
Only £25.99 inc VAT.
ORDER NOW
MSI GeForce GT 620 Low Profile 2048MB GDDR3 PCI-Express Graphics Card @ £43.99 inc VAT
Every PC deserves great graphics. NVIDIA GeForce GT 600-series graphics cards deliver premium multimedia performance-every time. Trust NVIDIA GeForce GT 630, 620, and 610 dedicated graphics for a faster, more immersive experience in your favorite applications.
- CUDA Cores: 96
- Core Clock (MHz): 700
- Processor Clock (MHz): 1400
- Memory Amount: 2GB DDR3
- Memory Bandwidth(GB/sec): 5.3
- Texture Fill Rate (billion/sec): 13 / 11.2
- Direct X 11
- Outputs: Dual DVI-I / VGA
- TDP: 49W
- 3yr Warranty
Was [£49.99] Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
MSI GeForce GT 630 2048MB GDDR3 PCI-Express Graphics Card @ £43.99 inc VAT
- CUDA Cores: 96
- Core Clock (MHz): 810
- Processor Clock (MHz): 1620
- Memory Interface: 128-bit
- Memory Clock (MHz): 1000 (2000 effective)
- Memory Bandwidth(GB/sec): 25.6
- Texture Fill Rate (billion/sec): 13 / 13
- Direct X 11
- TDP: 65W
- 3yr Warranty
ORDER NOW
MSI GeForce GT 630 4096MB GDDR3 PCI-Express Graphics Card @ £53.99 inc VAT
- CUDA Cores: 96
- Memory Amount: 4GB DDR3
- Direct X 11
- TDP: 65W
- 3yr Warranty
Was [£59.99] Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
MSI GeForce N210 SILENT 1024MB GDDR3 "Low Profile" PCI-Express Graphics Card @ £16.39 inc VAT
Graphics processing has become an essential ingredient to the modern PC. Nowadays, we simply demand more from our PCs. If you want to enhance photos, edit videos, watch movies, play games, or if you simply desire a Premium Windows® 7 Experience, the NVIDIA® GeForce® 210 graphics card brings impressive graphics processing power to your PC at an incredible value.
- Core Clock: 589MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1000MHz (Effective)
- Memory Interface: 64-Bit
- Processing Cores: 16
- Shader Clock: 1178MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: VGA, Dual-Link DVI-I & HDMI
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.1 Support
- CUDA Enabled
- Warranty: 3 Years
Was [£17.99] Inc. VAT
Only £16.39 inc VAT.
ORDER NOW
Awesome deals guys!! :D :D :D
Is the Asus GeForce GTX 670 DirectCU II 4096MB a dual slot or tri slot card? Can't tell from the pics. I'm thinking of getting two but they will be install one directly below the other.
Definitely needs a shake up. 780s are ridiculously priced at the moment whether they're on 'sale' or not.
Higher price and slower than pair of GTX670/680 7950/7970 is not really giving people incentive to buy them...they seriously need to be at at least sub £450...
I'm seriously tempted by the Asus GTX670 4GB...should I trade 7950's much higher memory bandwidth for PhysX, or pay £70 extra for the Asus 7970 Matrix Platinum, or wait for next gen AMD Hawaii cards....ahhhhhhhhhhhh!!!!!
The 7970 Platinum deal is hard to ignore :)
Asus 7970 Matrix. Hawaii is going to be priced high too.
I'll throw a spanner in the works and say for your 120hz 3D screen you should go 7950 crossfire. ;)
£350 for the cheapest 7950x2 or £370 for 2x7950 Ice-Q's. Sell or keep 6 games worth £50 or so.
Thing is were still moving through 200+ 780's per week, so I suspect the UK is easily managing 2k units per month and NVIDIA are only just keeping up with the demand, so if they move the price it will be because they want too, not because they need too.
How many 7950's and 7970's do you move compared to those 780's?
