** MEMORY PRICES CONTINUE TO ROCKET! LETS REVERSE THAT AT OCUK!!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Its no secret that due to a recent fire at the Hynix memory factory, prices are continuing to rocket, but for ONE WEEK ONLY on our Weekly Deals I am reversing our prices and actually selling below trade cost.
Why are we doing this? Well because at OcUK we know how to buy memory, so we purchased truck loads on the day of the fire before manufacturers re-aligned their pricing upwards.
So we've decided to place some of our best kits on offer, check them out:-
GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (GD38GB1333C9DC) @ £49.99 inc VAT
GeIL announces the launch of the new DDR3 Dragon RAM Series to be added to GeILs’ performance memory line of products. Not only does the Dragon RAM is tattooed with the GeIL dragon totem and crowned with two red LEDs as the dragon eyes, the PCB is eight layered instead of the usual six for maximum stability. As GeILs’ quality standard, the Dragon RAM will be reinforced with DBT – Die-hard Burn-in Technology for the highest quality assurance. Covering the most popular specifications of DDR3 today - 1333MHz and 1600Mhz, the Dragon RAM is the answer to an added value solution for the mainstream market.
Features:-
- PC3-10666 1333MHz CAS 9-9-9-24
- Designed for PC
- GeIL classic Dragon design
- 1.50v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge/Ivybridge or AMD AM3 based system
- Limited Lifetime Warranty
Was [£55.99] Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) @ £49.99 inc VAT
Features:-
- PC3-12800 1600MHz CAS 11-11-11-28
- Designed for PC
- 1.50v VDIMM
- Sandybridge/Ivybridge compatible
Was [£59.99] Inc. VAT
ORDER NOW
GeIL Black Dragon 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD316GB1600C11DC) **OcUK Exclusive** @ £99.95 inc VAT
Features:-
- Designed for PC
- 1.50v VDIMM
Was [£119.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Kingston HyperX Genesis 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3K2/8GX) @ £53.99 inc VAT
nonl2br
Kingston's KHX1600C9D3K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.<br>
<br>
Model Name: KHX1600C9D3K2/8GX<br>
Main Board: INTEL<br>
System: DESKTOP<br>
System Type: DDR3<br>
M/B Chipset: INTEL<br>
CAS Latency: 9-9-9-27 2N<br>
Capacity: 8GB (4GBx2)<br>
Speed: DDR3-1600 (PC3-12800)<br>
Test Voltage: 1.50-1.65V<br>
Registered/Unbuffered: Unbuffered<br>
Error Checking: Non-ECC<br>
Type: 240-pin DIMM<br>
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)<br>
Master Pack Weight: 0.26 lbs<br>
Black PCB<br>
Warranty: Lifetime<br>
<br>
<br>
<iframe width="560" height="315" src="
" frameborder="0" allowfullscreen></iframe>
Was [£65.99] Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX16C9K2/16X) @ £99.95 inc VAT
nonl2br
Kingston's KHX16C9K2/16X is a kit of two 512M x 64-bit 8GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.<br>
<br>
Model Name: KHX16C9K2/16X<br>
System: DESKTOP<br>
Capacity: 16GB (8GBx2)<br>
Black PCB<br>
<br>
<br>
ORDER NOW
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) @ £35.99 inc VAT
nonl2brKingston's KHX1600C9D3X2K2/4GX is a kit of two 256M x 64-bit 2GB (2048MB) DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 4GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.<br>
<br>
Model Name: KHX1600C9D3X2K2/4GX<br>
System: DESKTOP<br>
M/B Chipset: INTEL P67<br>
Capacity: 4GB (2GBx2)<br>
Black PCB<br>
<br>
<br>
Was [£41.99] Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £53.99 inc VAT
nonl2br
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.<br>
<br>
Model Name: KHX1600C9D3X2K2/8GX<br>
System: DESKTOP<br>
Black PCB<br>
<br>
<br>
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-15000C11 1866MHz Dual Channel Kit (KHX1866C11D3P1K2/8G) @ £71.99 inc VAT
nonl2brKingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. HyperX memory modules are designed for the high-performance and PC enthusiasts markets and offer high speeds and low latencies. Only the best components are used to assemble HyperX memory modules in order to guarantee the highest performance. All Kingston HyperX memory modules come with a lifetime warranty.<br>
<br>
Model Name: KHX1866C11D3P1K2/8G<br>
System: DESKTOP<br>
M/B Chipset: INTEL <br>
CAS Latency: 11-11-11-27 2N<br>
Speed: DDR3-1866 (PC3-15000)<br>
Test Voltage: 1.50-1.60V<br>
<br>
<br>
Was [£79.99] Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K) @ £53.99 inc VAT
The Intel® Extreme Masters (IEM) Memory, a limited edition kit designed with true performance and gamers in mind. These modules are hand tested and compatible with the latest Intel® DDR3 platforms to ensure stability for the most intense gaming environments. The Intel® XMP Certification ensures a seamless gaming upgrade and experience.
The Intel® Extreme Masters, Limited Edition utilizes the Viper 3 variation design for its heat dissipating capabilities for superior performance to ensure rock solid stability even when using the most taxing applications. Built with the highest quality of components, we back our memory with a lifetime warranty.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s IEM Edition will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts. This exclusive memory by Patriot Memory will only be available during Season 7 show of IEM. Visit www.intelextrememasters.com for more information.
Features:-
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (9-9-9-24)
- Voltage: 1.50-1.60V
- XMP Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel 6 & 7 series platform
- Lifetime Warranty
ORDER NOW
Patriot Intel Extreme Masters 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (PVI316G160C9QK) @ £99.95 inc VAT
Features:-
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
ORDER NOW
Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) @ £53.99 inc VAT
Patriot Memory’s Viper 3 Series memory kits are designed with true performance in mind. Tested and compatible with Intel’s® and AMD’s DDR3 compatible processors and chipsets, The Viper 3 series provides the best performance and stability for the most demanding computer environments.
The Viper 3 series utilizes a custom designed high performance heat shield or superior heat dissipation to ensure rock solid performance even when using the most taxing applications. Built from the highest quality Build of Materials, Patriot Memory’s Viper 3 Series memory kits are hand tested and validated for system compatibility.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s Viper 3 Series will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts and are XMP 1.3 eady. Hand tested for quality assurance, the Viper 3 series is backed by a lifetime warranty.
- Voltage: 1.5v
- XMP 1.3 Ready
- RoHS Compliant
- Tested on Intel® P67 and Z77 platform
ORDER NOW
Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV316G240C0K) @ £137.99 inc VAT
The Viper 3 series utilizes a custom designed high performance heat shield for superior heat dissipation to ensure rock solid performance even when using the most taxing applications. Built from the highest quality Build of Materials, Patriot Memory’s Viper 3 Series memory kits are hand tested and validated for system compatibility.
Specification:-
- Extreme Performance PC3-19200 (2400MHz)
- Low Latency (10-12-12-30)
- Voltage: 1.65V
- XMP 1.3 Ready
- RoHS Compliant
- Lifetime Warranty
Was [£149.99] Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
Patriot Venom Red 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV38G240C0KRD) @ £65.99 inc VAT
Specification:-
- Voltage: 1.65V
- XMP 1.3 Ready
- RoHS Compliant
- Lifetime Warranty
Only £65.99 inc VAT.
ORDER NOW
Patriot Venom Red 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV316G240C0KRD) @ £137.99 inc VAT
Specification:-
- Voltage: 1.65V
- XMP 1.3 Ready
- RoHS Compliant
- Lifetime Warranty
ORDER NOW
TeamGroup Elite 4GB (2x2GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED34GM1600HC11DC01) @ £29.99 inc VAT
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.
Features:-
- Module Type 240Pin L-DIMM 1600
- CL-tRCD-tRP-tRAS 11-11-11-28
- DRAM Density 256x8 / 512x8
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800)
- Heat Sink Aluminum heat-sink
- Working voltage 1.5V± 0.075V
- Warranty Lifetime warranty
Was [£35.99] Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) @ £49.99 inc VAT
Features:-
ORDER NOW
TeamGroup Elite Black 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED316GM1600HC11DC01) @ £95.99 inc VAT
Features:-
Was [£109.99] Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLD38G2400HC11CDC01) @ £59.99 inc VAT
Named after the god of fire in Greek mythology, the Team Vulcan is the combination of high-end craftsmanship and top-notch technology. The short version heat sink of Team Vulcan prevents difficulty in installation due to large and bulky heat dissipation device of motherboard. The arrow-shaped opening design helps increase heat dissipation. In addition, the explosively red color combined with diamond cut pattern not only shows great texture but also the crazy sensation of over-clocking speed.
Made of chips from major manufacturers, Team Vulcan passes series of harsh testing and verification procedures which have proven its stability and durability. Currently, DDR3 2400 CL10, DDR3 2133 CL11, DDR3 1866 CL9/10/11 and DDR3 1600 CL9 are available to cover the mainstream Dual- and Quad-channel specifications that pretty much satisfy the demands of players of all levels.
Features:-
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 11-13-13-35
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 19,200MB/Sec (PC3 19200)
- Working voltage 1.55V-1.65V
- Haswell & AMD Richland compatible
Was [£71.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLYD38G2400HC11CDC01) @ £59.99 inc VAT
Features:-
ORDER NOW
TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) @ £59.99 inc VAT
Features:-
ORDER NOW
Whats the catch?
1. This pricing will end next Wednesday Morning - You have ONE week!
2. There is no trade pricing to our business accounts - Web price only!
3. The prices next Wednesday will increase by £10-£30 per kit.
Why BUY NOW?
1. These prices will go up £10-£30 next Wednesday!
2. The prices could increase even further as demand increases due to busy season.
3. OcUK has the best customer service and offers lifetime warranty on all memory.
4. OcUK has the best UK pricing on memory, beating our competitors.
5. OcUK has one of the largest in stock memory ranges always. :)
6. OcUK has 2400MHz 8GB kits at prices below some of our competitors sell 8GB 1600MHz C11 kits at.
Not in a million years sorry, well certainly not this year or in 2014! :(
Yes i didn't fancy my chances. Regretting the day i ever sold 8gb for £35 in the MM now. It was even a struggle to sell it as well. 8gb now costs considerably more than 16gb cost me back in the day.
Yes
Most of our competitors are now in the £60-£75 region for an 8GB 1600 kit.
So the fact were still at sub £50 simply shows two things, were better buyers at memory and we pass the savings onto the customer. :)
But this will end next Wednesday as unfortunately we have to realise reality......
Nice prices. Tempted to get 32GB of 2400 RAM to replace my vengerance 1600. Any point with a X79 and 3930 in going from 1600 - 2400 ?
Silly questions time...
Would the Kingston C9 2x2GB sticks run observably faster than the Team Group C11 2x2GB?
Would it be worth spending the extra £5 per kit to join the ddr3 bangwagon rather late with 8GB, or should I just stick with ddr2 4GB I already have in my aging x48c platinum, keeping the money to save on a long overdue upgrade?
The x48C Platinum came out during the ddr2/ddr3 crossover period all those years ago, it has 2 ddr2 slots and 4 ddr3 slots (that have to be max 2GB sticks). ;)
Stick with ddr2 4GB you already have in your aging x48c platinum, keeping the money to save on a long overdue upgrade ;)
