You can't change your main car that's on the driveway.
Tervor has the 4x4
Franklin has the white mustang
Michael has the Audi
You can't change them.
It's not though. The disc carries on blaring away (old xbox 360 elite here). Have tested with other game I have installed to the hard drive and that works, ie no optical drive spinning after a few seconds.
Wtf is the impound? I found it once when doing the towing mission but can't find it any more lol.
NVM.
Does everyone else have a green motorbike at Franklin's on the drive as well as the white car?
I moved house and the white car and green bike are still on the drive.
it's not that one, it's on the map as a white car.
Hmm I don't have the car symbol on mine or am being a bit blind :S
You don't need your USB stick in that case as you should only install disc 1. Leave disc 2 in the drive.Disc one is installed to xbox hard drive. Disc 2 to the USB stick.
Feeling quite dense here, but I've just done the install play disc to a USB stick trick for the xbox version, and I can't make the game play from it. I see no option to play from the installed version on the usb stick anywhere, and the game just runs from the rom drive, as you have to have the disc in still I believe, even when you do this trick.
Help!
The USB drive install (for the 2nd Disk for the X-box) is not mandatory and in fact you need to be cautious.
The game basically is so big it is split into 2 discs, you install Disc 1 and never need it again and need Disc 2 in the tray to play. When playing (no install of Disc 2), the game extract data from both the HDD and Disc 2 to populate the in game environment. So the disc is always spinning at pretty much full speed all the time.
If you install both discs into the HDD, the HDD is just not fast enough to extract twice as much data at the same time for the game not to mention the SATA bandwidth will be saturated. The result is shorter draw distances and less detail on screen. The amount however is minimal, but still, it is not advised.
So to stop the disc spinning all the time with that noise, you put in a USB stick in the X-box (there is a USB socket at the back so it's out of the way) You only need a 16G stick as it is an 8G install (if you have an external HDD that would work too). Make sure it has a minimum read speed of 15MB/s. Configure it inside the X-Box.
Once installed, the game still need Disc 2 to load, you will hear it spin when loading up. But once loaded, you are now running in silence and it is now loading data from HDD and USB stick.
After seeing comparisons of it both installed on the hard-drive against a USB install, it just doesn't seem worth it. You can't notice it
Once it's installed between both the USB and the HDD do you just boot the game from the dashboard with the disc in as usual?
