- 24 Mar 2013
- C-137
Hi all,
I only posted this here as I PRESUME it's a motherboard fault.
So last night I was doing some light benching in Catzilla, and after hitting the wall with my 670's, I decided to push the cpu a little higher. It's at 4.5 usually, and I have had it upto 4.7 stable before so no biggie, I'll bump it up, run another bench and call it a night.
Now this is when things got a bit odd. So I went into the BIOS and changed my multi to 46 and tried to boot. No issues, booted fine. Fired up real temp and P95 for a quick stability check and my CPU freq was still at 4500. Weird.
rebooted, checked in bios, multi still at 47. Odd I thought, so I played around with every setting I possibly could, even reset to defaults and nothing. The original OC still remained. I raised the BCLK a little to see if it made a difference, which it did, getting me to 4525.7 or something, but the cpu multi would not change no matter what when I booted to windows.
What the dog-poo is going on? Has anyone else come across this or similar before? I can't find anything on google really either.
I have not tried removing cmos battery yet. Will be trying that later. Not convinced it will do anything though. I'm pretty sure it's a ****** bios. It's been a bit odd since I updated a few months back. Nothing that I can really put my finger on until now, but just general quirkiness.
Spec is:
3770k w/h100 x2 noctua nf-f12
asus p8z77-v
16gb corsair vengence lp 1600 c9
120gb ocz solid 3 and 480gb crucial m5
x2 MSI power ed OC gtx 670 2gb
Antec true power new 750w
Fractal design r4
Any thoughts/insight would be helpful.
Spec is:
asus p8z77-v
Fractal design r4
