upgrade help
6 Dec 2005
Cambridge, UK.
Hi Guys,
I am looking to upgrade my PC for gaming purposes, as my spec in sig is struggling (obviously).
I will be reusing the following for my new build:
Antec P182 ATX case
Corsair HX 520 PSU
Intel 520 180GB
Nvidia GTX 570 GPU
4x SATA hard drives
Windows 8
Dell 2007WFP (1680x1050 res, eventually would like to upgrade to a 27" monitor).
I am thinking of buying the following:
Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM
Corsair Hydro H60 V2 High Performance Liquid CPU Cooler
Gigabyte Z87M-D3H Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard
TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLYD38G2400HC11CDC01)
Total: £403.36 inc vat
I am a bit out of the loop of latest hardware, but have been searching through the forums. I have chosen a MATX motherboard as I would eventually like to down size my case to a smaller one. Is there much difference between a ATX and MATX motherboard these days apart from losing some expansion slots?
Any suggestions/changes?
N.B I don't really plan to overclock and would like to keep the upgrade cost down. I realise the CPU I have picked might be wasted in my build, but I could overclock in a few years.
Many thanks
fobse
Hi,
That looks pretty good so far.. Have you got an idea about what case you may be going to: TJ08-E, Prodigy M, Corsair 350D? If we know this we can spec you bits (CPU cooler mainly) which will fit that case too. :)
I would 100% change the H60 to any high end CPU cooler..
Do you have 2 spare 120mm fans by any chance, if so i can spec you a great cooler. :)
This confused me, which is it? Do you want to save money on not overclocking or spend money and potentially reap the benifits in the future? :)
Thanks for the quick reply. I have to go to work now and can't access the forums from work but I will think about the case I will hope to upgrade to. Thinking about it now I might even just keep the P182 to save myself the money and time rebuilding in to a new case. P.S if I do decide to keep my current case, is it worth changing the mobo to an ATX one (is there any main benefit other than expansion slots)?
Sorry yes I am in two minds about what I want to do. I dont want to have to source a new CPU in a few years so I think I best just stick to the 4670k. Especially as there is only a £40 difference between the 4440.
For the first time ever im incline to disagree :O I have this cooler its probably why lol.
Using the same cpu as you and playing crysis 3 for a couple hours stright my cpu never gets hotter than 38 with this cooler i think its bang on. Its small and nice looking too :)
I've no doubt doom could spec a better one but i dont see anything wrong with it.
Saying that if your unsure your even going to overclock i'd not bother full stop. One must make upeth ones mind :P
Its better imo to plan for an overclock coz sods law dictates you wont then a year or two down the line wish you did
There always a first, im sure it won't be the last either..
I completely understand.. I personally had a H50 in my rig until recently (february, actually not that recently) and its performed well but my D14 blows it out of the water..
I assume the H60 is a little biut better than my H50 but i got a 4.4 overclock with my H50 at 70C Max and a 4.7 on my D14 with 60C max.(my H50 was push/pull too, where as the standard H60 is pull only).
Im not saying its a bad cooler atall, its not but for £60 you can get better.
Sorry i completely missed this.. :)
The P182 is a nice case, though if you have ou mind on it no reason not to keep your options open..
The only real advangtage of at ATX board is Xfire/SLI.. Are you considering upgrading your PSU and adding another GPU? If not Matx is fine (its still possible with mATX boards).
I think the mATX board you've picked is great, it atleast gives you the option to grab a 350D/TJ08-E/Prodigy M in the future if funds appear. :)
Yeah good plan. :)
Though if you ween't overclocking you could save another £20 going for a H87/B85 Motherboard too.. and cheaper RAM (as H87/B85 don't really support above 1600mhz RAM).. and you won't need so good a CPU cooler. So the differnce will be about £90.
I have never had more than one GPU in my PC as of yet, and don't think I ever will (cost, power, potential noise - I like my PC to be silent). My HX 520 is about 5 years old but I think it will be ok for the new build.
Looking at some of the cheaper boards, a lot of them only have 2 memory slots. If I was to swap over to one with 2 slots, should I perhaps go for 2x8GB modules, or is that just over kill for gaming (what about in a couple of years)?
N.B I have kept my current PC since 2006, with the only additions of the intel 520 and GTX 570 which are being held back. So I probably wont upgrade for another 5 years at least lol.
Okay here are you options. :)
Non-overclocking version:
YOUR BASKET
1 x Intel Core i5-4440 3.10GHz (Haswell) Socket LGA1150 Processor - Retail £137.99
1 x Gigabyte H87M-HD3 Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £73.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £49.99
1 x Alpenföhn Matterhorn Pure Edition CPU Cooler £29.99
Total : £303.36 (includes shipping : £9.50).
Overclocking Version (using the 2 fans you already have)
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £179.99
1 x Gigabyte Z87M-D3H Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £97.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLD38G2400HC11CDC01) £59.99
1 x Prolimatech Megahalems Rev C CPU Cooler £42.98
Total : £392.35 (includes shipping : £9.50).
8GB will be enough for gaming though like you say 4 slots gives you chance to expand.. (i think 16GB is overkill)
As you're not interested in SLI, no real need for an ATX board. :)
Obviously the overclocking version would perform better at stock (high stock freq and RAM speed) but with a 4.2-4.5ghz overclock it will fly :) That cooler is upto the job. :)
EDIT: I was bang on with £90. :)
Many thanks Doomedspeed. I think I will pay the extra and get the o/c spec, and use the CPU cooler you have suggested too.
