- 19 Feb 2007
- Northampton
Running a 4770K at 4.60GHZ on the above mobo, would i get any bottlenecking ?
Which gpu's are you going to use? 2gb 670's here and a 4770k at 4.5ghz, the cpu is definitely not a problem in the games i play. But it will of course depend on the games you play the most yourself mate.
Why would you think the Sabertooth would give any problems?
Yep, no problems. The Sabertooth is a great board if you like the armour
What resolution are you at?
2 780's in SLI on my mobo and cpu wouldn't even bottleneck. You'll be fine mate.
