VPN IP could change at any moment.
Out of interest what's the/is there a risk in running your firewall and the stuff behind it virtualised all on the same hardware?
I've not really looked into virtualisation security so not sure if it's even an issue or not.
It seems like both you and I are on the same wavelength. As it stands, my HP Proliant only has 8GB of RAM, but for a simple website, I can't imagine this causing a great deal of trouble.
I was hoping you could tell me a little bit more about your three virtual machines and how they all work hand in hand. You mentioned the following: One acts a Proxy and run mod security, one is a normal web server and the other is the DB server.
What proxy and mod security do you have in place on your first VM? On your second, what webserver are you currently using? As for the third, I don't intend on storing any details so the use for a DB would be unnecessary.
You also mentioned your Juniper firewall and how that has been configured. Since I don't have the luxury of owning one of these, would pfSense be my next best option whilst running through another VM? Would this be required if my site was hiding behind my VPN?
Using something like no-ip or dyndns on the router gets around this.
Are you sure your isp aup allows commercial hosting from your home? What happens when the connection goes down and there's no sla? You say tough to the customer?
You can route everything via the VM so that the VM has the connection to the internet while your PC has it's gateway as the VM. Essentially you can make your PC much more secure by doing this as the traffic has already been filtered before it gets back to your PC.
M.
I used to have my own host at fasthosts but £80 a year for one site was to me a rip off. Now I host 3 sites and I have total control. Yes it has its downsides of no HA but if the site went for a day nobody would care. I would say read up give it ago its a great learning experience.
Thanks for the inspiration! This is definitely something I'm going to read up on as it sounds like an interesting side project, whilst at the same time, putting my server to some more good use!
On another note, have you ever had a DDOS attack that has brought down your network? Or are you hiding behind a firewall?
No DDOS at the moment. Cant see it being an issue as the sites dont generate that sort of attention.
Is your sites currently hiding behind any sort of VPN? Or is your firewall configured that you're not too concerned with your home IP being out in the open?
I was going to drop you a PM but unfortunately it doesn't look like we've got that facility via the OC forum. Is there particular sites you would recommend that I begin reading through in order to get myself started? Like another member previously stated, it would even be good to get a basic website up and running using my server as temporary hosting before making the siwtch over to dedicated hosting company.
As it stands, I'm only really looking for some basic hosting as I doubt my site will bring in a great deal of traffic. It's not going to be an e-commerce site or anything of that sort that would be expected to bring in a great deal of traffic. Instead, it will be a personal blog that should be fairly quiet.
Rather than spend the cash (no matter how low) I'd rather try and see how I get on using a number of Virtual Machines instead. Could you please link me to a few sites that you recommend I give a read to get myself started? pfSense obviously being one of them. The one thing I'm not entirely sure on is what OS to run my site on to begin with?!
