Caporegime
- 13 May 2003
- Warwickshire
IN that case wouldn't you much prefer a system + unvented?
I suggested the Valliant 937 as it's a all in one, but if space available then a Valliant 824 or similar & a megaflow cylinder is my usual suggestion, as it gives you mains pressure hot water.
Out of interest why would you spec a combi boiler with a cylinder for hot water ? I always thought this is what heat only or system boilers are for ?
Hot water at mains pressure, plus it's takes ages to fill a bath and turning on another hot tap will effect the flow to all the other outlets with combi.
With a megaflow or similar cylinder, you can fill a bath in a few minutes, it's also handy were you have two bathrooms,with a combi it takes considerably longer.
If you haven't the the space for a seperate cylinder, then a Vaillant 937 is a good compromise if you want a combi.
Was just curious why you would spec a combi boiler along with a cylinder as the Valliant 824 is combi boiler ? I would have expected a cylinder with a Valliant 624/630/637 system boiler or am I reading your post incorrectly ?
