Budget CPU + Mobo Advice Wanted :)
12 Apr 2013
Talke Pitts
Hey guys, I recently brought a MSI 7850 from OCUK great price now I need some more advice again.
My current motherboard is old, small (Flexatx) and my CPU is an intel G630, could anyone reccomend a CPU + Mobo combo which is worth upgrading my old hardware over but wont break the bank, Thanks! :)
- 1680 x 1050 Resolution
- Can be AMD or Intel
- Would I see any improvements in fps (None intensive CPU games)
- I don't video edit or any of that, Primary use is gaming
And an AMD alternative. Might want to get a better cooler though as these babies run hot!
YOUR BASKET
1 x AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £119.99
1 x Gigabyte 990FXA-UD3 AMD 990FX (Socket AM3+) DDR3 Motherboard £109.99
Total : £241.38 (includes shipping : £9.50).
I'd avoid that AMD board, lots of bad reports all over the internet. The Asus 970 EVO R2.0 if SLI/Crossfire isn't wanted (£90) is a lot better. Otherwise the Asus 990FX Pro, which is about the same price.
what is your budget? there is a 100 different price spec's that can be dont but 99 may not fit your price point
My budget is around 240, is there any cheaper intel processors you can reccomend.
Not bothered about overcloking.
Maybe i'll get that amd 8320
this is a cheap as an i5 will get
YOUR BASKET
1 x Intel Core i5-4440 3.10GHz (Haswell) Socket LGA1150 Processor - Retail £137.99
1 x MSI Z87M-G43 Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £91.99
Total : £240.78 (includes shipping : £9.00).
and in that case i would go AMD as the i5 can be over clocked and an amd can, you dont have to go 8 cores ever. 4 or 6 is fine
i take it you dont have any plans for massive overclocking and no plans to runn SLI this would do fine in that case
YOUR BASKET
1 x AMD Piledriver FX-6 Six Core 6300 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £89.99
1 x ASRock 970 Extreme3 R2.0 AMD 970 (Socket AM3+) DDR3 ATX Motherboard £65.99
Total : £167.38 (includes shipping : £9.50).
