They'll consume similar amounts of power overclocked.
For example I paid only £300 for my 4770K and the motherboard. You could pick up a 4670K and mobo for prob around £220+
Any examples? Bearing in mind the board needs to be solid for overclocking? I've been weighing this up for weeks and every way I look it the haswell option is about 30% more for not much more performance. I'd love to be proved wrong tho
I think you just answered your own question. If your happy spending more for slightly better performance which in real usage you probably wont notice then go haswell.![]()
That's my conclusion also, but some seem to swear otherwise so I keep wondering if im missing something!
The 4c/8t Xeon may be higher priced, but that's somewhat offset by needing a better motherboard for AMD.
The actual difference is like 30 quid at the most.
Either way, no option is particularly wrong, I'd look into the Xeons performance in VM's before anything though.
EDIT : There's always the second hand Z68 and 1155 i7 route.
The FX-8350 has better performance in VM's than your option.
Do you have some proof/benchmarks to qualify that statement?
Because I don't![]()
For myself? I use a 120HZ monitor, I need the the most consistent and stable performance, I need the highest minimums I can get.
Well my question certainly sparked more debate than I expected and I'm grateful for all the opinions. I still haven't decided 100% although the fact there is so much debate and no clear victor does, I think, show that each manufacturer has its own strengths and weaknesses. e.g. current power vs future power vs price/value. Once again thanks for the input and I shall have a further think.
