Smart phone is crazy inaccurate.. Mine recorded 92.6db from a gas turbine. No chance![]()
Why don't you try the app out?
It's for quite a random reason, I play the guitar (acoustic) and there's a forum where there's some talk of older guitars getting louder, certain types of construction and bracing and wood type being different volumes, one guy used an iPhone app and got 92db from a guitar that's kinda known for being a bit of a cannon, would be interesting to see some comparisons.
Although I too am highly dubious about the a db meter app, especially as Ive read most 'cheap' mics can't hear anything above so many decibels, and it varies from device to device,galaxy s3 aapparently can't register anything above 82db, where as the s2 can apparently go up to 95db. Then you've got to hope the app is actually accurate.
Be nice to have an easy way for a bunch of people to test without having to fork out for any specialist equipment, as it's only a bit of fun.
It may not be accurate but my smartphone app helps me to adjust all my guitar and amp volume settings which it is capable of doing.
So for instance I use a James Tyler JTV-59 which emulates many famous guitars but the four I use on stage have different volumes which are noticeable.
I put my amp on clean and then using my guitars Workbench software I'm able to adjust each sound to exactly the same db and then save those four guitars into my presets.
On stage I noticed that my main 4 amp sounds weren't quite accurate (clean, distortion, lead solo and heavy distortion) so using the smartphone app I made 3 of them exactly the same db and the lead channel is 6db louder which is perfect on stage.
Last weekend all my guitar & amp sounds were bob on![]()
Useful but a big un amplified acoustic can probably hit the 90's at close range.
So place the phone further back.
I put mine about 10 foot away and all the volumes are around 70db but my amp is on a lowish volume.
