My Asus 7970 DCII Top was brilliant, never a problem with it and it was the quietest card I've ever had.
Is it right to assume you never did any OCing on it then?
No, I ran it at 1135MHz.
Mine was voltage locked at 1.08v and I didn't know about the custom BIOS to change it until I'd put it up for sale. At a higher voltage it'd have easily gone up higher.
1.A custom BIOS is a bit easier than sticking a water block on it,
2.and the Matrix Platinum isn't voltage locked.
3.Plus you can't even buy reference 7970s new.
I'd rather have 1135MHz and a voltage locked silent card than something that sounds like a jet engine. I tried Asus GPU Tweak. It wasn't that bad. You can still use MSI Afterburner to change core and memory clocks once you've set the voltage.
Anyway, I was more than happy with my Asus 7970 DCII and if I were going to buy a new 7970 I'd happily get another.
Matrix Platinum is ONLY voltage unlocked in ASUS GPU Tweak, and that is an application you would hate to see.
All 7970s are.
I assume he's got at least one 8 pin but not two.
thanks for all the responses. I have been
1.researching a lot on the Matrix and have yet to come across any negatives.
2. I personally trust Asus. my current GTX 480 is an Asus and has been brilliant so far and have always used Asus in the past as well and never had any problems.
3. (i have ROG mobo on my work pc & sabertooth on my gaming pc)
4. All things point to the Matrix, im just in hunt for a decent PSU. the matrix + psu will be only slightly more than the 770 i was planning to get to begin with. i will sell my psu, which is a really good psu and it should make up for the difference.
any suggestions on the psu, i'll be glad to hear it. min 750watts and must be modular
1. No negatives? Have you been ignoring my posts?
2. Just because asus made good 480s or whatever doesnt mean their 7970s doesnt suck.
3. We're not talking about mobos. It's irrelevant.
4. NOTHING points toward a Matrix except for the abundant advertising about more phases and better caps etc etc. And you bit the bait and you're gonna pay for it. You'll see. Your card wont be any where near as impressive as most oced reference cards. If you're not OCing? Well then you just failed completely because you could get any other 7970 for much less.
1. Are you implying ref 7970s will run out of overclock "headroom" ?The biggest problem is GPU Tweak, it is quite poor.
1.I tried it out on my Titans last night and ran out of adjustment before my cards ran out of overclocking headroom lol, fortunately this does not happen with the Matrix.
2. As to the HD 7970 Matrix Platinums, they are very nice cards and faster than 90% of other HD 7970s.
3.If used with waterblocks I would expect to get higher clocks than you with yours as they have 1.4v available to them straight out the box.
1. Who said you need a waterblock? I beat your super ultra OC DC2 card with my 100% normal reference card only because mine wasnt voltage locked. The reference cooler is perfectly capable of cooling OCd cards, its just louder.
2. Matrix Platinum is ONLY voltage unlocked in ASUS GPU Tweak, and that is an application you would hate to see.
3. http://www.newegg.com/Product/Product.aspx?Item=N82E16814102961 <--- This one is ref for sure. These ones are worth checking out: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161399 http://www.newegg.com/Product/Product.aspx?Item=N82E16814129204
Probably better to just get a standard 7970 if you're having to get a new PSU as well.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-273-AS&groupid=701&catid=56&subcat=938
Is a cracking deal IMO. You couldn't get 7950s for that price a while back.
