size? connectivity?
both can perform equally, mATX gives more options.
there's no ITX with 4 RAM slots for example.
Bitfenix just announced Prodigy M that can accomodate mATX.
given it's got pretty much the same external dimensions (as original Prodigy) and can accomodate mATX as well as ITX, definitely yes.
just not sure about UK availability. In Germany it starts shipping 14/10 as of today.
Snips is right, 8gb is plenty for gaming and most other tasks you're likely to throw at it. 16gb is overkill unless you're rendering large scenes, running a server or if you're editing large video files I believe it can help.
I'd say the only real limitation of ITX is the single PCIe slot. And perhaps the lack of case choice to some degree, though if you already like the Prodigy then that's not an issue, other than the fact that for an ITX case it is enormous, hence them being able to redesign it to fit a mATX board in it without changing the dimensions lol
I've got a little 3770K ITX build with a GTX 670 and I love it, the only thing I want to do is get a nice small case for it, but it's proving difficult to find something I like. There are a lot of ITX cases hitting the market soon so I've got it running in an old full ATX case whilst I'm waiting.
Would you plan to over clock or like the ability to add a 2nd graphics card for SLI/Xfire in the future?
It's a pretty basic spec motherboard but it depends what you need from it.
It's got 2 sata 6gbs and 2 sata 3gbs and a header for the cases front mounted, USB 3.0's.
You could sacrifice the water cooler and get a better graphics card if you wanted but I just think it looks so awesome with the red coolant.
YOUR BASKET
1 x BenQ XL2411T 24" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red £251.99
1 x MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** with FREE GAMES £199.99
1 x Intel Core i5-4440 3.10GHz (Haswell) Socket LGA1150 Processor - Retail £143.99
1 x OcUK Tech Labs Fathom All in One Custom Cooler 240mm £112.97
- 1 x XSPC EX240 120mm Radiator - Black £41.99
- 1 x Mayhems X1 UV Red Premixed Watercooling Fluid 1L £7.99
1 x Corsair Obsidian 350D Windowed Micro ATX Case - Black £94.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £83.99
1 x Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) £79.99
1 x CM Storm Quickfire TK Mechanical Keyboard - Red Switch £72.98
1 x Seasonic G series 550w '80 Plus Gold' Modular Power Supply £71.99
1 x Razer DeathAdder 2013 6400 DPI Essential Ergonomic Gaming Mouse £64.99
1 x Patriot Venom Red 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (PV38G160C9KRD) £59.99
1 x Western Digital Caviar Green 1TB SATA 6Gb/s 64MB Cache - OEM (WD10EZRX) **SINGLE PLATTER** HDD £53.99
1 x Gigabyte H81M-D2V Intel H81 (Socket 1150) DDR3 Micro ATX Motherboard £51.95
1 x BitFenix Alchemy 24-Pin ATX Extension 30cm - sleeved black/red/black £7.49
1 x BitFenix 6-Pin PCIe Extension 45cm - sleeved black/red/black £5.99
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Red £5.99 (£11.98)
1 x BitFenix Molex to 4x SATA Adapter 20 cm - sleeved black/red/black £5.99
1 x BitFenix 8-Pin PCIe Extension 45cm - sleeved black/red/black £5.95
1 x BitFenix Alchemy 8-Pin EPS12V Extension 45cm - sleeved black/red/black £4.99
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Red £4.49
1 x BitFenix Alchemy 2pin I/O extension 30cm - Red £3.95
Total : £1,444.60 (includes shipping : FREE).
