Prolimatech Magnetic Fan Pins (4pack) - Black @ £3.95 inc VAT
These magnetic pins allow you to fix you fans to your chassis without the presence of vibration noises that normal screws provide.
- Material: Rubber / metal
- Color: Black
- Contents: 4 magnetic rubber pins in storage box
- Compatibility (fan): without continuous web of the mounting holes
- Compatibility (housing): material: ferromagnetic (eg steel, nickel)
Only £3.95 inc VAT.
ORDER NOW
_
Asus HD 7970 DirectCU II TOP 3072MB GDDR5 PCI-Express Graphics Card with FREE Games **FREE SHIPPING** @ £224.99 inc VAT
The next generation Asus HD7970-3GD5 graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
This GPU Tweak function links the GPU clock frequency to the voltage, so as you scale the GPU clock the voltage automatically follows; a useful tool for inexperienced Overclockers, It also enables users to select between 2D and 3D mode by providing the ability to change the respective clock speeds, voltages and fan speeds of either. Disabling the 2D mode also forces the faster 3D mode, stabilising overclocking and benchmarking results.
Embedded with GPU-Z to access accurate graphics card information, the card also contains a live update driver and BIOS benefiting users with the ability to keep their card in the best condition. Widget monitoring provides the choice to display the most needed information including a full widget, light widget or real time monitoring.
Furthermore, new PCI Express 3.0 delivers improved encoding and twice the performance of the previous PCI Express 2.0 and vision horizons can be expanded across six displays with AMD Eyefinity technology. This technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
- Cranked 75MHz over reference for an ultimate engine clock of 1000MHz
- All new DirectCU thermal design utilizes six all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Acclaimed DIGI+ VRM with 12-phase Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking
- VGA Hotwire allows you to plug and solder wires on the card’s voltage regulators and accurately read and control Vcore, Vmem, and PLL voltages on a hardware level
- GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface
- One card drives up to six screens with AMD Eyefinity™ 6
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5600MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- AMD Golden Ticket: Choose any three games from AMD (Select 3 FREE Games from AMD upto December 31st 2013)
- FREE Shipping: Buying this product entitles you to FREE SHIPPING on your entire order!
- 3yr Warranty
Only £224.99 inc VAT.
ORDER NOW
- Color: Black
Only £3.95 inc VAT.
ORDER NOW
_
- 3yr Warranty
ORDER NOW
