Cooling the New Prodigy M!
26 Dec 2004
Sweatshop.
Hey guys,
well the new Prodigy M Drops in two weeks, and to make most of the MATX Mobo and the future prospect of SLI i want to mount the CPU rad differently.. i'll be using a h100i by the way.
this is how the new M looks.
im thinking mount the rad on the outside, use the stock fans on outside also and have a nice grill on the top (so it'll hide them), now inside i'm thinking a set of SP120s, but how should i have the airflow, as the GPU will be directly below the rad?
Baring in mind you can have another set of fans on the bottom of the case either 2 x 120mms, or a 240mm
Opinions welcome! :)
On some pictures it shows a 230mm fan in the bottom of the case (i think its was 230mm and not 180mm) and at first glance i thought i saw holes for 2 x 120mm fans but they seem to be holes for the HDD mounts... Which is a shame..
