AllBenchmark Catzilla 1.0
Permabanned
15 Oct 2011
Nottingham Carlton
After months and many betas Finall version is here
Download link:
http://www.catzilla.com/download
I start first :)
ATM 7th place 720p on AMD Single GPU config :]
I still get issues running this benchmark. Starts up, but a split second after it starts (when panning down the tower block) the gfx stop. Music/sfx still carries on playing fine though.
No problems with anything else - games and 3dmark etc work fine.
This used to work - I think on early 13.x amd drivers - but not since then. On 13.10 beta ones now. May try the 13.9 release and see of that helps - although since only this benchmark is effected may not bother. :D
I thought i'd give this a try
3x 7970's @ 1125/1575 (stock voltage) and 3930k @ 4.6 (stock voltage) plus other bois and memory tweaks.
I reckon there's another 3k in this system.
fizzy ye it was same for me last few betas. Atm i am on 8.1 with 13.9 and it runs like it should. Hard to say if its drivers or benchmark.
I do like this anyway and its only few $.
Support Polish programers.
Those chaps made Witcher !!!
Uninstalled 13.10 beta, and installed 13.9 Whql drivers - and it works again. Must be something enabled in the betas it doesn't like (some debugging options maybe?).
Quick run through and I got a score of 16414 - but that was at 576p as I haven't registered yet. :)
