What does he need?[/Q
hi thanks for the reply, he doesn't need peripherals, optical drive, neither a monitor
So....full tower?
Without OS this is about the best I can do, only slightly over. I'd want to add a cooler so the CPU could be overclocked to 4.5GHz or so.
Alternatively, drop down to the 7850 graphics card and up the CPU to the 8320.
YOUR BASKET
1 x Sapphire HD 7870 GHz Edition 2048MB GDDR5 PCI-Express Graphics Card (11199-16-20G) £149.99
1 x Asus M5A97 EVO R2.0 AMD 970 (Socket AM3+) DDR3 Motherboard £86.99
1 x AMD Piledriver FX-6 Six Core 6300 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £83.99
1 x TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (TLYD38G1600HC9DC01) £56.99
1 x Akasa Venom 550w Modular '80 Plus' Power Supply £53.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £49.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
Total : £514.92 (includes shipping : FREE).
YOUR BASKET
1 x Asus HD 7850 DirectCU II V2 2048MB GDDR5 PCI-Express Graphics Card £131.99
1 x AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £113.99
Total : £526.92 (includes shipping : FREE).
Uh oh. Intel vs AMD debate incoming!
That second spec is the same mobo, CPU and GPU I have. Although only just upgraded so can't comment too much yet. I'd say it would leave an easier upgrade path though.
The 6300 and 8320 perform very similarly for older games, but the 8320 runs faster on new ones. Personally I'd take the 8320, since it will never run worse than a 6300, and a graphics card can easily be upgraded later. If you're not looking to order now, the new AMD GPUs are out very soon.
The 6300 and 8320 are essentially the same CPU except the 8320 has 8 cores instead of 6. Not many games use more than 4 cores at the moment, but the next gen games will be using 8.
Intel is the choice if you can afford it. As soon as you constraint it with a low budget then AMD is a good option. You can look to the MM or second hand route to factor in i5 choices however that is up to you to decide.
thanks for the replies, so is the most popular AMD cpu for gaming the piledriver series as there are many series, and is the 8350 better than the 8320, isorry i am a noob with amd CPU's![]()
The 8350 is a slightly higher clocked 8320, identical CPU otherwise. All FX CPUs can be overclocked though.
Don't go near Bulldozer.
whats the difference between the AM3+ 900 chipset andthe 700 chipset, which one is for the 8350 ?
Teppic.. im getting a 8350 and wanted 2 get alittle be better card is the Asus M5A99X PRO R2.0 AMD 990X good enough for the 8350?
