- 2 Dec 2007
- Leeds
this has me very intrigued....at least its something different!
The pads are clickable buttons also.
Looks like its aimed at shooters where you only click to fire, something like Fifa would be better on the 360 controller
the problem that is see is in fps's where is the ls and rs buttons as without those how will you be able to run and things like that.
You never just fire. Theres jumping, hiding, selecting weapon, secondry fire, run etc.
Amd far from convinced about trackpads, if nothing else they make your fingers hurt after a while dur to abration, ehich you dont get with sticks.
From the pictures it looks like there are 2 bumper buttons on each side which your index fingers rest on, so that's 2 trackpads (one for look direction, one for move direction), two buttons in the trackpads (shoot and crouch?), four bumpers for zoom, sprint, jump and reload, and what looks like two trackpads underneath the controler for your fingers (scroll wheel for weapons?).
It's just not going to work for some things (stuff like the X-series which are notorious for huge amounts of controls) but it's an interesting change to the more conventional style.
That pad looks terrible, what species is it designed for?
Have you tried using trackpads on laptops for any length of time? Painful fingers is an understatment.
